This is a placeholder topic for “Waterproof SMD DS18B20 Digital Temperature Sensor” comments.
This waterproof SMD DS18B20 temperature sensor provides 9-bits to 12-bit (configurable) temperature measurement and communicates over a 1-Wire bus that by…
how long is the cable on this sensor?
The other version has 90cm long cable. Is the length same in the SMD version? Hope core electronics team will clarify. Thanks.
Hi Steven,
Very sorry about the delay in getting back to you!!
Some just arrived in and I measured 1000 mm from the base of the sensor to the end of the insulation, we’ll also be sure to add that to the product page
Thank you. Adding this info to the product description will really help.
