Hi
Can anyone confirm if the WT32-ETH01 (DFR0963) has a RS232 chip or does only have TTL level serial? IE I need to purchase a RS232 adapter to connect it standard serial port.
Mike
Hi Mike,
I’ll preface this with I don’t have one in front of me.
It does mention UART around the product page so I’d be confident in hooking it up to a serial adapter like this: CP2102N USB-to-Serial Adapter Carrier | POLOLU-1317 | Core Electronics Australia
No, that won’t work. It does not have the correct usb interface.
Hi Mike,
What interface do you need?
An indicated in my initial post I need to know if the board has ttl serial and/or rs232 interfaces.
Hi Mike,
Sorry, had to touch up on TTL vs RS232.
The programming interface is TTL, so you’ll need a converter
