Core
5 September 2022 04:12
1
This is a placeholder topic for “1.25mm Pitch 5-pin Cable Matching Pair 10 cm long - Molex PicoBlade Compatible” comments.
These solid 1.25mm pitch connector cable pairs are great when you need something that can carry a couple amps of current and are easy to connect and disconnect.
Is there any way to buy this with a Female on both sides instead of just one side?
James
5 September 2022 04:57
3
Hi Xavier,
You could either order 2 sets, or assemble your own connectors:
51047-0500 - Connector Housing, PicoBlade 51047, Plug, 5 Ways, 1.25 mm, 50217 Crimp Terminal
Buy Plug & Socket Connector Contacts. element14 offers special pricing, same day dispatch, fast delivery, wide inventory, datasheets & technical support.
The wires in our circuits are often forgotten when we are planning our next big project, but the right connectors will a make your project look more professional and a lot easier to work with! In this tutorial, we are going to have a quick look at...
