This is a placeholder topic for “15A Single DC Motor Driver” comments.
This is an ultra small size DC motor driver for room limited projects, while the impressive IC - LM2575 could provide a powerful way to drive 36V@15A motors. Also its UVLO (Under Voltage Latch-Out) feature provides a safe guard for your system. Besides all, it is very considerate to own an 5V output for Arduino or any other devices, and its interface is ESD (electro-static discharge) protection.
15A Single DC Motor Driver SKU: DRI0042 there is a diagram on your site for this item; there is an electronic display of the speed - what do you recommend for that display? Thanks.
Hi Steve
I think the “electronic display” you are referring to may be a bench power supply displaying probably 15A and 24V. Not speed.
OK Bob thanks.
Hi Steve
Also check our range of add-on motor encoders by searching ‘Motor Encoder Kits’. These kits can be used to add an encoder to your motor, which can then be read by some form of logic on say an Arduino to obtain accurate motor speed.
Alternatively, if you search ‘Encoder Motor’ we have a bunch of motors with inbuilt encoders already available. They can be connected to some logic to perform the same task.
