1M RGB LED Strip - APA102c 144 Per Meter - White Strip - Weatherproof (CE05986)
This is a placeholder topic for “1M RGB LED Strip - APA102c 144 Per Meter - White Strip - Weatherproof” comments.
This is a roll of addressable (APA102c) RGB LEDs. Each LED has a built-in controller chip which allows you to daisy-chain the LEDs and control them individually with a super fast refresh rate!
What is the strip width (excluding weather cover)?
Hey there, @JianShin338284, and welcome to the forum. Glad to have you here.
I measured this strip from the shelf at approximately 12 mm wide, excluding the weatherproof cover. That lines up with @James84823’s 11.98 mm measurement of the black version too.
