Core Electronics Forum
5M RGB LED Strip - WS2812B 30 Per Meter - White Strip - Weatherproof (CE04853)
This is a placeholder topic for “5M RGB LED Strip - WS2812B 30 Per Meter - White Strip - Weatherproof” comments.
This is a roll of addressable (WS2812B) RGB LEDs. Each LED has a built-in controller chip which allows you to daisy-chain the LEDs and control them individually - all from a single GPIO!
what is the width of the 5M RGB LED Strip - WS2812B
once programmed does the strip save the program without needing to be connected?
is there any device that could make the control of the LED strip compatible with a remote control?
thank you, good sir
Hi shamilla,
The strip is approximately 10mm wide. The strip is not able to be programmed, it must always be connected to a device that is controlling it.
The simplest place to start to control these is an Arduino Uno. You can write the code to control the LEDs onto that:
