3-pin LiPo Charger
Does anyone know of a charger for a 3-pin LiPo battery, preferably USB-C?
I assume this is not suitable due to needing a 12VDC 5A input.
I have a similar one with a built in power supply, 250VAC input.
Works very well.
Hi Adam,
The charger Jim linked will work perfectly.
The yellow wire is a temperature sensor so you won’t be able to plug it straight in, you’ll need some kind of adapter.
You could also use and 1 cell lipo charger.
Hi James, thanks for your help. I guess I’ll search or make an adapter.
