PowerBoost 1000C is the perfect power supply for your portable project! With a built-in load-sharing battery charger circuit, you’ll be able to keep your power-hungry project running even while recharging the battery! This little DC/DC boost converter module can be powered by any 3.7V LiIon/LiPoly battery, and convert the battery output to 5.2V DC for running your 5V projects.
This thing does what many USB power banks simply can’t: supply a load and charge a battery at the same time, and seamlessly switch the load to battery power when the charger is disconnected. Why is this cool? It could be the basis of a UPS for a single board computer. Or a data logging project that needs to run even in a black out (say monitoring the temperature of a freezer). Or would be great for an automotive project that needs to cleanly shutdown after the ignition is cut off.
Quick and efficient service.
Our 20,000mAh battery features a third wire for the inbuilt NTC thermistor that boards like the PiJuice read to determine whether they are pushing the battery too hard and it’s getting too hot.
You could definitely crimp a 2-pin connector on, or strip the wires and solder them directly to the pins on the powerboost, but it won’t be plug-and-play
Thanks James, I have not had the best of luck with getting the pijuice to work with that battery. Would you know what I would need to get this module to work?
Blake
Copied from Core page product alert: Note - this is a generic LiPo battery that is compatible with PiJuice by using a custom profile in the PiJuice configuration software. The standard PiJuice battery profiles may not work as intended with this battery.
This is quoted directly underneath
This 20000mAh Lithium-Ion battery is compatible with the PiJuice
Confusing what!!!
Unfortunately am not familiar with RPi so cannot offer a solution.
I think those statements were trying to add up to “this will work with a bit of configuration”. The PiJuice itself comes with a moderately sized battery that will work out-of-box, but anything significantly larger/smaller in capacity would behave differently, and thus need a different profile.
PiJuice have a good guide on the paramaters that need to bet set:
I’m really just exploring options. My ESP32 with a thermometer should work for around two weeks on a battery and even without Wi-Fi being used it depletes in 3 days. It measures every minute and turns the display for a few seconds and goes to sleep, then repeats. I will be optimizing wake up timings, and when display is on and maybe try to wake up and send measurements only when temp changes or maybe once in 10 minutes max.
