This is a placeholder topic for “5m Flexible Addressable RGB LED Wire (WS2812 compatible)” comments.
This attractive, individually-addressable RGB LED wire is perfect for making your own programmable fairy lights. ??..
Read moreThis is a placeholder topic for “5m Flexible Addressable RGB LED Wire (WS2812 compatible)” comments.
Read moreConnecting 5m Flexible Addressable RGB LED Wires [SKU: COM3214]
Can you strip both ends to solder multiple strips together? Where can you cut them? Thanks!
Hi @QwertyKids, Welcome to the Forums!!!
You can cut the wire to be able to strip and solder additional string together.
As far as I can tell you can cut them anywhere between the LEDs as it is just 3 strands of wire between each LED.
I hope this helps with your project ![]()
Thank you! We thought so too but have so far had no joy. We’ll try again and report back.
If you could send through some pictures we might be able to see what might be causing the issue.
I would double check you have the data in and out sides the correct way around.
