This is a placeholder topic for “6xAA Battery Holder(double layer)” comments.
This battery holder can hold 6 AA battery which can make 7.2 V rechargeable battery pack from NiMH / NiCd cells or 9V battery pack from alkaline cells.
Read moreThis is a placeholder topic for “6xAA Battery Holder(double layer)” comments.
Read moreWhat are the physical dimensions for this 6xAA battery holder ?
I would like to use this as replacement for a Ni-MH 1800 mAh 7.2v sealed battery pack in solar powered security light (1500lm), but it will be dependent on the dimensions.
This is the Jaycar item, which appears to be the same:
Electus Distribution - Battery Holder made out of high grade plastic with nickel plated terminals for 6 AA square with leads to wire into a circuit
Hey @Douglas103595 and @Jeff105671
Just measured this up and added the dimensions to the site for you, please let me know if you have any other questions:
