A4988 heatsink
Hi gurus, the A4988 stepper motor driver has a small heat sink supplied. I presume that heat sink paste is used, but won’t the little bugger fall off down the track? How do you keep it keeping on?
Looking forward to some good responses and correct ones as well!
Hi Frank,
I recommend thermal tape to both adhere and transfer heat:
https://core-electronics.com.au/heat-sink-thermal-tape-3m-8810-80mm-x-80mm.html
Thank you Stephen
