ADA377 Schematic
Hi there, complete beginner here,
I have a had a look round and haven’t had any luck finding kicad/.step files for ADA377.
I was hoping someone on here might have some lying around?
Thanks,
Josh
I think those are not open source…
Step is here:
12mm Rotary Encoder with 6mm Shaft | 3D CAD Model Library | GrabCAD
Hi Josh
Rotary encoder data sheet here
There is a link on the Core product page for the encoder which is called.
PEC11-4215F-S24 datasheet
Which is the actual encoder. A bit confusing as it references the actual encoder and is the only place that information appears. It looks like that unit is just the bare encoder with a knob fitted and given another name.
Cheers Bob.
Incidentally this is a Bourns encoder if it is the actual one used. This is a quality product.
