hi Team,
I acquired a couple of the Adafruit feathers from you guys. ADA4062
I am trying to connect to them so I can flash them using the Arduino IDE on a macbook.
I am following these instructions:-
however I am unable to see the device itself in the list of USB devices. I understand it should be visible as soon as I plug it in. It’s not, and as a result - i cannot move forward.
I have tried both of the Adafruits I purchase (2 x ADA4062) and I have checked the cable works (other devices appear as soon as I plug them in)
I have even tried 2 x macbooks.
I am likely doing something stupid, but I cannot work it out.
I’ll do some more digging to see if its even being detected in Mac OS - something like device manager.
EDIT: running the command ioreg -p IOUSB -l -w0 should show the connected devices if any are present, also Apple menu > About the Mac > System report > Hardware > USB. This should display the list of connected devices, if another device/Arduino handy a good check would be plugging one in.
Make sure you arent pulling too much current through the USB port, i.e. shorts on connectors, if its resting on anything metal or stuff has been soldered onto it
Make sure the drivers are up to date
Unplugging everything except the microcontroller (MC) - including USB hubs
Hi pr
Probably not much to do with your problem but may be relevant.
Some time ago purchased a NanoEvery and it could not be seen or located per the Arduino IDE. I somewhere found out that the web based version of the IDE found devices automatically if connected when Arduino IDE started. This worked and since then I have had no trouble. The NanoEvery appears whenever I use the “normal” IDE when I require it.
May be worth a try. Connect your device then start the web based IDE and see if your device is found.
