Hi trying to make GPS work - Issues LED light flashes when first powered on and doesn’t change status when connected to serial port no data is transmitting.
Any suggestions ?
Hey Annette,
Before we go any further with this one, are you able to give us a bit more detail regarding the setup you have? e.g. what you are using to read the serial data, the code you have written if you are implementing something like an Arduino, the hardware setup you have etc.
We’ll try and get you a resolution for this ASAP!
Hi Annette,
With your GPS module were you using it outside? They usually need a couple of satelite connections to start working, I would recommend trying it there.
Let us know how you go!
Regards,
Liam.
