Hi - I’m using an ADS1015 with a temp sensor/thermistor. The ADC is reporting values (not voltages) in the range of 16,000. As it is a 12 bit ADC and I’m using ads.gain = 1, I expected 0-4096 … clearly I’m missing something - any idea?
The register values are left justified within 16-bits, so that needs to be factored into your conversion code. The data sheet shows the values you can expect:
INPUT SIGNAL OUTPUT CODE
≥ +FS (2^11 – 1)/2^11 7FF0h
+FS/2^11 0010h
0 0000h
–FS/2^11 FFF0h
≤ –FS 8000h
FS is determined by the gain.
Thank you Jeff - got it figured out!
