Core Electronics Forum
Storing and retrieving data in array's... I think!
Guys,
I think I need help with arrays.
Im working with the ADS1115 and have started to think about the Gain function, specifically how I can code it efficiently.
Essentially, the Gain is set based upon a maximum input voltage to the ADS1115, like this:
Gain Values (Set for maximum input voltage):
0 : 6.144V
1 : 4.096V
2 : 2.048V
3 : 1.024V
4 : 0.512V
5 : 0.256V
Currently my code simply states:
gain_value = 1
max_inp_volts = 4.096
…and then I use these values elsewhere in the code.
In my case though, the maximum input voltage is derived from another function that is dependant on another variable (water tank height). I would like to be able to say something like:
if water_tank_height = x, then gain_value = 4 and max_inp_volts = 0.512
I can fathom the logic to establish what the gain_value should be, but dont know how to efficiently and automatically call the correct gain_value and max_inp_volts.
I could do it in a series of if, then, else statements but that seems very inefficient.
Any thoughts guys?
Jon
Is something like this what you are looking for ?
When water height is ‘whatever’ 10 in this case gain is set to 4 and the 4th element of the array is the volts (0.512).
const float inp_volts[6] = { 6.144, 4.096, 2.048, 1.024, 0.512, 0.256};
int gain_value = 0;
int water_tank_height = 0;
void setup() {
void loop() {
if (water_tank_height == 10) { gain_value = 4; }
max_inp_volts = inp_volts[gain_value];
Wow, that was quick! Many thanks, that looks great.
I had it in my mind that the gain_value and the inp_volts needed to be in the array and therefore would need some kind of look-up.
This way looks simpler and just as good:)
Thanks.
Jon
