So the test code below is the one that works and moves through each shift register -
- A random (between 1 and 4) number of leds follow the leader
#include <HC595.h>
const int chipCount = 4; // Number of serialy connected 74HC595 (8 maximum)
const int latchPin = 3; // Pin ST_CP (12) of the 74HC595
const int clockPin = 4; // Pin SH_CP (11) of the 74HC595
const int dataPin = 2; // Pin DS (14) of the 74HC595
//Constructor
HC595 ledArray(chipCount,latchPin,clockPin,dataPin);
int delayMs = 200;
int lastPin = ledArray.lastPin();
void setup() {
ledArray.reset();
randomSeed(analogRead(A0)); //nothing connected to A0
void loop() {
int followers = random(1,5);
for(int i = 0 ; i <= lastPin ; i++) {
ledArray.setPin(i, ON);
if (i >= followers) ledArray.setPin(i-followers, OFF);
delay(delayMs);
for (int i = lastPin-followers ; i <= lastPin; i++) {
ledArray.setPin(i, OFF);
delay(delayMs);
The code below is what I’ve started editing and is based on another project, the difference with this is that each shift register was individually connected back to an output on the Arduino whereas I am daisy chaining my shift registers which is the difficult part for me in trying to work out how/what I need to change for the below to work for my setup.
#include <boarddefs.h>
#include <IRremote.h>
#include <IRremoteInt.h>
#include <ir_Lego_PF_BitStreamEncoder.h>
#include <XC3718_codes.h>
/* Scoreboard Version 7.0 - FINAL
This is the code for a Softball scoreboard keeping double
digit score for visitor and home, innings, and outs.
Using the IR Remote library from:
IR Remote
http://arduino-info.wikispaces.com/IR-RemoteControl
based on code by Ken Shirriff - http://arcfn.com
Get Library at: https://github.com/shirriff/Arduino-IRremote
Unzip folder into Libraries.
RENAME folder “IRremote”
MY STUFF:
The scoreboard uses 4 Seven-Segment LEDs that are made up of LED strips
They are controlled by an Arduino Nano with 4 shift
registers using 3 pins only.
VISITOR HOME
_ _ _ _ |_| |_| |_| |_| |_| |_| |_| |_| tens ones tens ones
The LED strips use 12V for power and the Arduino cannot power that.
A 12V power supply is hooked up directly to +12v of each strip.
Each arduino pin goes to a MTP3055VL which in turn allows the current
to flow through to each individual LED strip.
___________ | |
| MTP3055VL | |___________|
G || D || || S || || ||
To Arduino Pin--|| || ||---to GROUND ' | (+12V)_____________________ ' |---To LED Segment_______________|__0___0___0____LED Segment */ /* Four (4) Shift Registers are used, 74HC595. Letters indicate segment of 7-Segment LED. A
F B
|G|
E C
|D|
Pin Designation for the shift Register as follows:
- B 16. +5V (X = not used)
- C 15. A
- D 14. Data
- E 13. GND
- F 12. Latch
- G 11. Clock
- X 10. +5V
- GND 9. X
/ IR Receiver Pins
_____ | |
| IR | |_____|
`To Arduino Pin#11 --| | |—to +5V Power
’ |—To GROUND
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
//Pin connected to ST_CP of 74HC595
int latchPin = 3;
//Pin connected to SH_CP of 74HC595
int clockPin = 4;
////Pin connected to DS of 74HC595
int dataPin = 2;
// Assign Shift Register Pins for Data, latch and Clock
int dataPinVT = 14; //Visitor Tens Shift Register
int latchPinVT = 12;
int clkPinVT = 11;
int dataPinVO = 30; //Visitor Ones Shift Register
int latchPinVO = 28;
int clkPinVO = 27;
int dataPinHT = 46; //Home Tens Shift Register
int latchPinHT = 44;
int clkPinHT = 43;
int dataPinHO = 62; //Home Ones Shift Register
int latchPinHO = 60;
int clkPinHO = 59;
// Initialize what will be displayed
int visitorTensDisplay = 0;
int visitorOnesDisplay = 0;
int homeTensDisplay = 0;
int homeOnesDisplay = 0;
// Set counters to zero for displays
int visitorCount = 0;
int homeCount = 0;
// Declare pins as outputs
void setup()
pinMode(latchPinVT, OUTPUT);
pinMode(clkPinVT, OUTPUT);
pinMode(dataPinVT, OUTPUT);
pinMode(latchPinVO, OUTPUT);
pinMode(clkPinVO, OUTPUT);
pinMode(dataPinVO, OUTPUT);
pinMode(latchPinHT, OUTPUT);
pinMode(clkPinHT, OUTPUT);
pinMode(dataPinHT, OUTPUT);
pinMode(latchPinHO, OUTPUT);
pinMode(clkPinHO, OUTPUT);
pinMode(dataPinHO, OUTPUT);
// Enable the IR stuff
Serial.begin(9600);
irrecv.enableIRIn(); // Start the receiver
// Initalize the displays
visitorTensDisplay=127;
visitorOnesDisplay=127;
homeTensDisplay=127;
homeOnesDisplay=127;
// Not sure, I think this maps the seven segments
// VISITOR TENS AND ONES
digitalWrite(latchPinVT, LOW);
shiftOut(dataPinVT,clkPinVT,MSBFIRST,visitorTensDisplay);
digitalWrite(latchPinVT, HIGH);
digitalWrite(latchPinVO, LOW);
shiftOut(dataPinVO,clkPinVO,MSBFIRST,visitorOnesDisplay);
digitalWrite(latchPinVO, HIGH);
// HOME TENS AND ONES
digitalWrite(latchPinHT, LOW);
shiftOut(dataPinHT,clkPinHT,MSBFIRST,homeTensDisplay);
digitalWrite(latchPinHT, HIGH);
digitalWrite(latchPinHO, LOW);
shiftOut(dataPinHO,clkPinHO,MSBFIRST,homeOnesDisplay);
digitalWrite(latchPinHO, HIGH);
void loop() {
// IR stuff: basically decodes the keypress from the remote in a switch case
if (irrecv.decode(&results)) {
switch (results.value)
case 0xFF11EE:
Serial.println("Dog");
break;
case 0xFF619E: // POWER (Resets all all counts to 0)
for(int i=0; i<3; i++){
delay(1000);
visitorTensDisplay=0;
visitorOnesDisplay=0;
homeTensDisplay=0;
homeOnesDisplay=0;
delay(1000);
Serial.println("Power button");
break;
case 0xFFA15E:
Serial.println("Mute");
break;
case 0xFF30CF:
Serial.println("One");
break;
case 0xFF18E7:
Serial.println("Two");
break;
case 0xFF7A85:
Serial.println("Three");
break;
case 0xFF10EF:
Serial.println("Four");
break;
case 0xFF38C7:
Serial.println("Five");
break;
case 0xFF5AA5:
Serial.println("Six");
break;
case 0xFF42BD:
Serial.println("Seven");
break;
case 0xFF4AB5:
Serial.println("Eight");
break;
case 0xFF52AD:
Serial.println("Nine");
break;
case 0xFF6897:
Serial.println("Zero");
break;
case 0xFF629D: // UP (increases the visitor count by one)
visitorCount = visitorCount+1;
if(visitorCount>99){ // after 99 runs, counter goes back to 0
visitorCount = 0;
Serial.println("CH");
break;
case 0xFFA25D: // DOWN (decreases the visitor count by one)
visitorCount = visitorCount-1;
if(visitorCount<0){
visitorCount = 0;
Serial.println("CH-");
break;
case 0xFF22DD: // LEFT (decreases the home count by one)
homeCount = homeCount-1;
if(homeCount<0){
homeCount=0;
Serial.println("<<");
break;
case 0xFF02FD: // RIGHT (increases the home count by one)
homeCount = homeCount+1;
if(homeCount>99){ // after 99 runs, counter goes back to 0 and no negative counts
homeCount = 0;
Serial.println(">>");
break;
case 0xFF39C6:
Serial.println("Menu");
break;
case 0xFFF10E:
Serial.println("Display");
break;
case 0xFFC936:
Serial.println("Band");
break;
case 0xFFE916:
Serial.println("Memory");
break;
case 0xFFB946:
Serial.println("Return");
break;
case 0xFF718E:
Serial.println("Radio");
break;
delay(100);
// Visitor Count Switch-case, displays Visitor score from 0-99
switch (visitorCount){
case 0:
visitorOnesDisplay = 63;
break;
case 1:
visitorOnesDisplay = 6;
break;
case 2:
visitorOnesDisplay = 91;
break;
case 3:
visitorOnesDisplay = 79;
break;
case 4:
visitorOnesDisplay = 102;
break;
case 5:
visitorOnesDisplay = 109;
break;
case 6:
visitorOnesDisplay = 125;
break;
case 7:
visitorOnesDisplay = 7;
break;
case 8:
visitorOnesDisplay = 127;
break;
case 9:
visitorOnesDisplay = 111;
break;
case 10:
visitorTensDisplay = 6;
break;
case 11:
break;
case 12:
break;
case 13:
break;
case 14:
break;
case 15:
break;
case 16:
break;
case 17:
break;
case 18:
break;
case 19:
break;
case 20:
visitorTensDisplay = 91;
break;
case 21:
break;
case 22:
break;
case 23:
break;
case 24:
break;
case 25:
break;
case 26:
break;
case 27:
break;
case 28:
break;
case 29:
break;
case 30:
visitorTensDisplay = 79;
break;
case 31:
break;
case 32:
break;
case 33:
break;
case 34:
break;
case 35:
break;
case 36:
break;
case 37:
break;
case 38:
break;
case 39:
break;
case 40:
visitorTensDisplay = 102;
break;
case 41:
break;
case 42:
break;
case 43:
break;
case 44:
break;
case 45:
break;
case 46:
break;
case 47:
break;
case 48:
break;
case 49:
break;
case 50:
visitorTensDisplay = 109;
break;
case 51:
break;
case 52:
break;
case 53:
break;
case 54:
break;
case 55:
break;
case 56:
break;
case 57:
break;
case 58:
break;
case 59:
break;
case 60:
visitorTensDisplay = 125;
break;
case 61:
break;
case 62:
break;
case 63:
break;
case 64:
break;
case 65:
break;
case 66:
break;
case 67:
break;
case 68:
break;
case 69:
break;
case 70:
visitorTensDisplay = 7;
break;
case 71:
break;
case 72:
break;
case 73:
break;
case 74:
break;
case 75:
break;
case 76:
break;
case 77:
break;
case 78:
break;
case 79:
break;
case 80:
visitorTensDisplay = 127;
break;
case 81:
break;
case 82:
break;
case 83:
break;
case 84:
break;
case 85:
break;
case 86:
break;
case 87:
break;
case 88:
break;
case 89:
break;
case 90:
visitorTensDisplay = 111;
break;
case 91:
break;
case 92:
break;
case 93:
break;
case 94:
break;
case 95:
break;
case 96:
break;
case 97:
break;
case 98:
break;
case 99:
break;
// Home Count Switch-case, displays Home score from 0-99
switch (homeCount){
case 0:
homeOnesDisplay = 63;
break;
case 1:
homeOnesDisplay = 6;
break;
case 2:
homeOnesDisplay = 91;
break;
case 3:
homeOnesDisplay = 79;
break;
case 4:
homeOnesDisplay = 102;
break;
case 5:
homeOnesDisplay = 109;
break;
case 6:
homeOnesDisplay = 125;
break;
case 7:
homeOnesDisplay = 7;
break;
case 8:
homeOnesDisplay = 127;
break;
case 9:
homeOnesDisplay = 111;
break;
case 10:
homeTensDisplay = 6;
break;
case 11:
break;
case 12:
break;
case 13:
break;
case 14:
break;
case 15:
break;
case 16:
break;
case 17:
break;
case 18:
break;
case 19:
break;
case 20:
homeTensDisplay = 91;
break;
case 21:
break;
case 22:
break;
case 23:
break;
case 24:
break;
case 25:
break;
case 26:
break;
case 27:
break;
case 28:
break;
case 29:
break;
case 30:
homeTensDisplay = 79;
break;
case 31:
break;
case 32:
break;
case 33:
break;
case 34:
break;
case 35:
break;
case 36:
break;
case 37:
break;
case 38:
break;
case 39:
break;
case 40:
homeTensDisplay = 102;
break;
case 41:
break;
case 42:
break;
case 43:
break;
case 44:
break;
case 45:
break;
case 46:
break;
case 47:
break;
case 48:
break;
case 49:
break;
case 50:
homeTensDisplay = 109;
break;
case 51:
break;
case 52:
break;
case 53:
break;
case 54:
break;
case 55:
break;
case 56:
break;
case 57:
break;
case 58:
break;
case 59:
break;
case 60:
homeTensDisplay = 125;
break;
case 61:
break;
case 62:
break;
case 63:
break;
case 64:
break;
case 65:
break;
case 66:
break;
case 67:
break;
case 68:
break;
case 69:
break;
case 70:
homeTensDisplay = 7;
break;
case 71:
break;
case 72:
break;
case 73:
break;
case 74:
break;
case 75:
break;
case 76:
break;
case 77:
break;
case 78:
break;
case 79:
break;
case 80:
homeTensDisplay = 127;
break;
case 81:
break;
case 82:
break;
case 83:
break;
case 84:
break;
case 85:
break;
case 86:
break;
case 87:
break;
case 88:
break;
case 89:
break;
case 90:
homeTensDisplay = 111;
break;
case 91:
break;
case 92:
break;
case 93:
break;
case 94:
break;
case 95:
break;
case 96:
break;
case 97:
break;
case 98:
break;
case 99:
break;
//IR STUFF
irrecv.resume(); // Receive the next value
