I got the argon one v2 case and most of the times it works great.
However, I’m getting a weird problem with the video output.
When I’m plugged to a monitor directly through an HDMI cable it’s ok. But when I try using the same monitor but through an HDMI to VGA converter and a VGA cable it doesn’t show anything.
It also doesn’t work when I’m using a projector, either with HDMI cable or a VGA cable with the adapter.
Everything used to work before getting the case (including the adapter), so I’m thinking that there is a problem with the extra board that comes with the case.
I’ve tried some solutions that I found on this forum by adding/changing lines on the config.txt but nothing seems to work. To be honest I’m not completely sure what those lines actually do, now I have them all commented out with an “#”. I didn’t use them all at once, I just left the ones that I’ve tried so I wouldn’t repeat them. Here is the list:
#hdmi_force_hotplug=1
#hdmi_force_mode=1
#hdmi_ignore_edid=0xa5000080
#hdmi_drive=2
#hdmi_safe=1
#core_freq_min=500
#hdmi_group=1
#hdmi_mode=1
One more thing to add. If I’m plugged to the monitor directly though HDMI and I plug a second monitor through a VGA cable (with an adapter) both screens work.
It seems that it can’t boot correctly if I’m not plugged directly through HDMI.
I have a raspberry pi 4 2GB ram and I’m using manjaro xfce.
I really need it to work with the projector and the VGA cable.
Any suggestions will be appreciated.
