I’m trying to use the SparkFun LTE cat M1/NB-IoT shield to trigger relays when specific text messages are received, and I’m having trouble setting the new message indication via AT command.
See code below. The problem I’m having is with the line: lte.println(“AT+CNMI=2,2,0,0,0”);
// AT Command to receive a live SMS.
Every single example I can find online about operating something with arduino via SMS, includes this AT command. But when I try this command in the serial monitor with an AT passthrough sketch, it retuns: +CMS ERROR OPERATION NOT SUPPORTED.
do I need to add additional AT setup commands to the sketch in order for it to work?
#include <SoftwareSerial.h> //software serial library for serial communication b/w arduino & GSM
SoftwareSerial lte(8, 9);//connect Tx pin of GSM to pin 8 of arduino && Rx pin of GSM to pin no 9 of arduino
// Relays connected to pins 3 & 4
const int UP = 3;
const int DOWN = 4;
String textMessage;
void setup()
lte.begin(9600); // Setting the baud rate of GSM Module
Serial.begin(9600); // Setting the baud rate of Serial Monitor (Arduino)
delay(20000);
lte.println("*AT+CNMI=2,2,0,0,0*"); // AT Command to receive a live SMS
delay(1000);
// Set relay as OUTPUT
pinMode(UP, OUTPUT);
pinMode(DOWN, OUTPUT);
// By default the relay is HIGH
digitalWrite(UP, LOW);
digitalWrite(DOWN, LOW);
void loop()
if(lte.available()>0){
textMessage = lte.readString();
Serial.print(textMessage);
delay(10);
if(textMessage.indexOf("U")>=0){
digitalWrite(UP, HIGH);
delay(300);
Serial.println("UP");
textMessage = "";
if(textMessage.indexOf("D")>=0){
digitalWrite(DOWN, HIGH);
delay(300);
Serial.println("Down");
textMessage = "";
