Hi there I’m very new to electronics, but have a background in programming and a spare Raspberry Pi 3 B… so I thought this could be a fun project to learn with! I’d like some advice on the parts list I’ve put together just to make sure it’s possible with the components I’ve chosen
The design is simple, a hopper that sits over an auger, which pushes dry food pellets out into a bowl. The hopper/auger unit will sit on a load cell so the feeding can be automatically stopped when enough food has left the hopper.
I’m sure a pi is probably overkill but given I already have one and can write python I think it’s the simplest way for me to get started.
That should all go quite nicely. Have you had any ideas for a power supply yet? I checked out the ratings for your motor and it’s about 3.4V at ~1.7A phase, should be able to get away with just powering this off a regulated battery supply if that’s suitable for you. Also, why go with a load cell rather than using a spring and microswitch, or an ultrasonic sensor to determine whether the bowl was full? It should be a suitable option, I’m just curious why that’s the option you’ve chosen to go with
If you have any other questions please feel free to ask, enjoy your afternoon mate!
The reason for going with the load cell is that my cats are on a diet so I need a way to accurately tell how much food is being dispense, not just an indicator of if it did/didn’t dispense. If there’s another kind of weight/pressure sensor that would be better suited then I’m not married to the load cell. It was just the first component I found that seemed like it would do the trick haha
Thanks for the recommendation on the power supply. Do you have a link to one in particular?
