Hi Pi Gurus,
How do I make a bootable backup of my SD drives with Pi OS and Windows 10?
Thanks.
Hi Pi Gurus,
Thanks.
Thanks anyone…
Hi Larry,
I found this guide which should get you out of trouble: https://howchoo.com/g/nmexndnlmdb/how-to-back-up-a-raspberry-pi-on-windows
From there you should be able to use RPi imager to reflash the card.
Hey Larry,
Excellent question! The guide that @Liam120347 linked is perfect, how did you go with getting those ones backed up?
I think the solution will work, but I have not had a chance to do it.
Personally I’m a fan of Win32diskimager:
But there’s also a backup tool available in the Pi OS under Menu->Accessories->SD Card Copier. This is actually a utility called PiClone, and there’s a good description of its functionality here:
https://www.raspberrypi.org/forums/viewtopic.php?p=1434070&sid=51e6fa05f23a82c5041500fc630dcf87#p1434070
That’s cool, I already migrated to Windows 10 on my Pi400, so I guess I will stick with Windows based utilities.
