I don’t have a Uno or Nano handy so I can’t test that unfortunatly.
I have tried altering the CAN library so it makes a call to startTransaction and endTransaction each time SPI is used see the below code. The settings are set to 10MHz and I tried SPI_MODE0, SPI_MODE1, SPI_MODE2, SPI_MODE3. The sheild is still failing to initialise
mcp_can.h
2015 Copyright (c) DFROBOT Technology Inc. All right reserved.
Author:Jansion
Contributor:
2015-5-25
#include "df_can.h"
#define ReadWriteOneByte SPI.transfer
#define Read() SPI.transfer(0x00)
// SPI settings 10MHz
SPISettings settings(10000000, MSBFIRST, SPI_MODE1);
void MCPCAN::mcp_reset(void)
SPI.beginTransaction(settings);
MCPSPI_SELECT();
ReadWriteOneByte(MCP_RESET);
MCPSPI_UNSELECT();
SPI.endTransaction();
delay(10);
INT8U MCPCAN::mcp_readRegister(const INT8U RegAddr)
INT8U ret;
MCPSPI_SELECT();
ReadWriteOneByte(MCP_READ);
ReadWriteOneByte(RegAddr);
ret = Read();
MCPSPI_UNSELECT();
return ret;
void MCPCAN::mcp_readMulitiRegisters(const INT8U RegAddr, INT8U *buf, INT8U len)
INT8U i;
if ( len > CAN_MAX_MESSAGE_LENGTH)
len = CAN_MAX_MESSAGE_LENGTH;
MCPSPI_SELECT();
for (i=0; i < len; i++) {
buf[i] = Read();
MCPSPI_UNSELECT();
void MCPCAN::mcp_setRegister(const INT8U RegAddr, const INT8U value)
MCPSPI_SELECT();
ReadWriteOneByte(MCP_WRITE);
ReadWriteOneByte(value);
MCPSPI_UNSELECT();
void MCPCAN::mcp_setMulitRegisterS(const INT8U RegAddr, const INT8U *buf, const INT8U len)
INT8U i;
MCPSPI_SELECT();
ReadWriteOneByte(buf[i]);
MCPSPI_UNSELECT();
void MCPCAN::mcp_modifyRegister(const INT8U RegAddr, const INT8U mask, const INT8U data)
MCPSPI_SELECT();
ReadWriteOneByte(MCP_BITMOD);
ReadWriteOneByte(mask);
ReadWriteOneByte(data);
MCPSPI_UNSELECT();
INT8U MCPCAN::mcp_readStatus(void)
INT8U ret;
MCPSPI_SELECT();
ReadWriteOneByte(MCP_RX_STATUS);
ret = Read();
MCPSPI_UNSELECT();
return ret;
INT8U MCPCAN::mcp_setMode(const INT8U newMode)
INT8U ret;
mcp_modifyRegister(MCPCANCTRL, MODE_MASK, newMode);
ret = mcp_readRegister(MCPCANCTRL);
ret &= MODE_MASK;
if ( ret == newMode )
return MCP_OK;
return MCP_FAIL;
INT8U MCPCAN::mcp_configRate(const INT8U canSpeed)
INT8U preSet, cfg1, cfg2, cfg3;
preSet = 0;
switch (canSpeed)
case (CAN_5KBPS):
cfg1 = MCP_16MHz_5kBPS_CFG1;
cfg2 = MCP_16MHz_5kBPS_CFG2;
cfg3 = MCP_16MHz_5kBPS_CFG3;
break;
case (CAN_10KBPS):
cfg1 = MCP_16MHz_10kBPS_CFG1;
cfg2 = MCP_16MHz_10kBPS_CFG2;
cfg3 = MCP_16MHz_10kBPS_CFG3;
break;
case (CAN_20KBPS):
cfg1 = MCP_16MHz_20kBPS_CFG1;
cfg2 = MCP_16MHz_20kBPS_CFG2;
cfg3 = MCP_16MHz_20kBPS_CFG3;
break;
case (CAN_31K25BPS):
cfg1 = MCP_16MHz_31k25BPS_CFG1;
cfg2 = MCP_16MHz_31k25BPS_CFG2;
cfg3 = MCP_16MHz_31k25BPS_CFG3;
break;
case (CAN_33KBPS):
cfg1 = MCP_16MHz_33kBPS_CFG1;
cfg2 = MCP_16MHz_33kBPS_CFG2;
cfg3 = MCP_16MHz_33kBPS_CFG3;
break;
case (CAN_40KBPS):
cfg1 = MCP_16MHz_40kBPS_CFG1;
cfg2 = MCP_16MHz_40kBPS_CFG2;
cfg3 = MCP_16MHz_40kBPS_CFG3;
break;
case (CAN_50KBPS):
cfg1 = MCP_16MHz_50kBPS_CFG1;
cfg2 = MCP_16MHz_50kBPS_CFG2;
cfg3 = MCP_16MHz_50kBPS_CFG3;
break;
case (CAN_80KBPS):
cfg1 = MCP_16MHz_80kBPS_CFG1;
cfg2 = MCP_16MHz_80kBPS_CFG2;
cfg3 = MCP_16MHz_80kBPS_CFG3;
break;
case (CAN_83K3BPS):
cfg1 = MCP_16MHz_83k3BPS_CFG1;
cfg2 = MCP_16MHz_83k3BPS_CFG2;
cfg3 = MCP_16MHz_83k3BPS_CFG3;
break;
case (CAN_95KBPS):
cfg1 = MCP_16MHz_95kBPS_CFG1;
cfg2 = MCP_16MHz_95kBPS_CFG2;
cfg3 = MCP_16MHz_95kBPS_CFG3;
break;
case (CAN_100KBPS):
cfg1 = MCP_16MHz_100kBPS_CFG1;
cfg2 = MCP_16MHz_100kBPS_CFG2;
cfg3 = MCP_16MHz_100kBPS_CFG3;
break;
case (CAN_125KBPS):
cfg1 = MCP_16MHz_125kBPS_CFG1;
cfg2 = MCP_16MHz_125kBPS_CFG2;
cfg3 = MCP_16MHz_125kBPS_CFG3;
break;
case (CAN_200KBPS):
cfg1 = MCP_16MHz_200kBPS_CFG1;
cfg2 = MCP_16MHz_200kBPS_CFG2;
cfg3 = MCP_16MHz_200kBPS_CFG3;
break;
case (CAN_250KBPS):
cfg1 = MCP_16MHz_250kBPS_CFG1;
cfg2 = MCP_16MHz_250kBPS_CFG2;
cfg3 = MCP_16MHz_250kBPS_CFG3;
break;
case (CAN_500KBPS):
cfg1 = MCP_16MHz_500kBPS_CFG1;
cfg2 = MCP_16MHz_500kBPS_CFG2;
cfg3 = MCP_16MHz_500kBPS_CFG3;
break;
case (CAN_1000KBPS):
cfg1 = MCP_16MHz_1000kBPS_CFG1;
cfg2 = MCP_16MHz_1000kBPS_CFG2;
cfg3 = MCP_16MHz_1000kBPS_CFG3;
break;
default:
preSet = 1;
break;
if (!preSet) {
mcp_setRegister(MCP_CNF1, cfg1);
mcp_setRegister(MCP_CNF2, cfg2);
mcp_setRegister(MCP_CNF3, cfg3);
return MCP_OK;
else {
return MCP_FAIL;
void MCPCAN::mcp_initBuffers(void)
INT8U i, a1, a2, a3;
a1 = MCP_TXB0CTRL;
a2 = MCP_TXB1CTRL;
a3 = MCP_TXB2CTRL;
for (i = 0; i < 14; i++) {
mcp_setRegister(a1, 0);
mcp_setRegister(a2, 0);
mcp_setRegister(a3, 0);
a1++;
a2++;
a3++;
mcp_setRegister(MCP_RXB0CTRL, 0);
mcp_setRegister(MCP_RXB1CTRL, 0);
INT8U MCPCAN::mcp_init(const INT8U canSpeed)
INT8U res;
res = mcp_setMode(MODE_CONFIG);
if(res > 0)
delay(10);
return res;
delay(10);
if(mcp_configRate(canSpeed))
delay(10);
return res;
delay(10);
if ( res == MCP_OK ) {
mcp_initBuffers();
mcp_setRegister(MCPCANINTE, MCP_RX0IF | MCP_RX1IF);
mcp_modifyRegister(MCP_RXB0CTRL,
MCP_RXB_RX_MASK | MCP_RXB_BUKT_MASK,
MCP_RXB_RX_STDEXT | MCP_RXB_BUKT_MASK );
mcp_modifyRegister(MCP_RXB1CTRL, MCP_RXB_RX_MASK,
MCP_RXB_RX_STDEXT);
res = mcp_setMode(MODE_NORMAL);
if(res)
delay(10);
return res;
delay(10);
return res;
void MCPCAN::mcp_writeid( const INT8U mcp_addr, const INT8U ext, const INT32U id )
uint16_t canid;
INT8U tbufdata[4];
canid = (uint16_t)(id & 0x0FFFF);
if ( ext == 1)
tbufdata[MCP_EID0] = (INT8U) (canid & 0xFF);
tbufdata[MCP_EID8] = (INT8U) (canid >> 8);
canid = (uint16_t)(id >> 16);
tbufdata[MCP_SIDL] = (INT8U) (canid & 0x03);
tbufdata[MCP_SIDL] += (INT8U) ((canid & 0x1C) << 3);
tbufdata[MCP_SIDL] |= MCP_TXB_EXIDE_M;
tbufdata[MCP_SIDH] = (INT8U) (canid >> 5 );
else
tbufdata[MCP_SIDH] = (INT8U) (canid >> 3 );
tbufdata[MCP_SIDL] = (INT8U) ((canid & 0x07 ) << 5);
tbufdata[MCP_EID0] = 0;
tbufdata[MCP_EID8] = 0;
mcp_setMulitRegisterS( mcp_addr, tbufdata, 4 );
void MCPCAN::mcp_readid( const INT8U mcp_addr, INT8U* ext, INT32U* id )
INT8U id_Buf[4];
mcp_readMulitiRegisters( mcp_addr, (INT8U *)id_Buf, 4 );
*id = (id_Buf[MCP_SIDH]<< 3) + (id_Buf[MCP_SIDL]>>5);
if ( (id_Buf[MCP_SIDL] & 1 << 3))
*id = (*id<<2) + (id_Buf[MCP_SIDL] & 0x03);
*id = (*id<<8) + id_Buf[MCP_EID8];
*id = (*id<<8) + id_Buf[MCP_EID0];
*ext = 1;
void MCPCAN::mcp_writecanMsg( const INT8U sidh_addr)
INT8U mcp_addr;
mcp_addr = sidh_addr;
mcp_setMulitRegisterS(mcp_addr+5, can_Dta, can_Dlc );
if ( can_Rtr == 1)
can_Dlc |= MCP_RTR_MASK;
mcp_setRegister((mcp_addr+4), can_Dlc );
mcp_writeid(mcp_addr, can_ExtFlg, can_ID );
void MCPCAN::mcp_readcanMsg( const INT8U idh_addr)
mcp_readid( idh_addr, &can_ExtFlg,&can_ID );
can_Rtr = mcp_readRegister( idh_addr - 1 );
can_Dlc = mcp_readRegister( idh_addr + 4 );
if ((can_Rtr & (1 << 3))) {
can_Rtr = 1;
else {
can_Rtr = 0;
can_Dlc &= MCP_DLC_MASK;
mcp_readMulitiRegisters( idh_addr+5, (INT8U *)can_Dta, can_Dlc);
void MCPCAN::mcp_starttransmit(const INT8U mcp_addr)
mcp_modifyRegister( mcp_addr-1 , MCP_TXB_TXREQ_M, MCP_TXB_TXREQ_M );
INT8U MCPCAN::mcp_getNextFreeTXBuf(INT8U *txbuf_n)
INT8U res, i, ctrlval;
INT8U ctrlregs[MCP_N_TXBUFFERS] = { MCP_TXB0CTRL, MCP_TXB1CTRL, MCP_TXB2CTRL };
res = MCP_ALLTXBUSY;
*txbuf_n = 0x00;
for (i=0; i < MCP_N_TXBUFFERS; i++) {
ctrlval = mcp_readRegister( ctrlregs[i] );
if ( (ctrlval & MCP_TXB_TXREQ_M) == 0 ) {
*txbuf_n = ctrlregs[i]+1;
res = MCP_OK;
return res;
return res;
* @brief the MCPCAN class' constructor.
* @parameter:
@_CS:
indicate the spi select pin when mcu commication with the can controler e.i MCP2515
* @return void
MCPCAN::MCPCAN(INT8U _CS)
SPI_CS = _CS;
pinMode(SPI_CS, OUTPUT);
MCPSPI_UNSELECT();
* @brief: initialize the Can controler.
* @parameter: void
* @return void
void MCPCAN::init(void)
SPI.begin();
mcp_reset();
* @brief: config the the Can baud rate, buffer, and interrupt.
* @parameter: void
* @return if successful, it return CAN_OK, or CAN_FAILINIT
INT8U MCPCAN::begin(INT8U speedset)
INT8U res;
res = mcp_init(speedset);
if (res == MCP_OK) return CAN_OK;
else return CAN_FAILINIT;
* @brief: initialize the mask register.
* @parameter:
@Masker_num:
maybe set MCP_RXM0 or MCP_RXM1.
@ext:
extend flag. if ext = 1, indicate the frame is extended frame.
* @return the status. if success, return MCP_OK.
INT8U MCPCAN::init_Mask(Masker_t Masker_num, INT8U ext, INT32U ulData)
INT8U res = MCP_OK;
delay(10);
if(res > 0){
delay(10);
return res;
if (Masker_num == MCP_RXM0){
mcp_writeid(MCP_RXM0SIDH, ext, ulData);
else if(Masker_num == MCP_RXM1){
mcp_writeid(MCP_RXM1SIDH, ext, ulData);
else res = MCP_FAIL;
if(res > 0){
delay(10);
return res;
delay(10);
return res;
* @brief: initialize the fileter register.
* @parameter:
@Masker_num:
maybe set MCP_RXF0, MCP_RXF1、 MCP_RXF2、 MCP_RXF3、 MCP_RXF4、 MCP_RXF5.
@ext:
INT8U MCPCAN::init_Filter(Filter_t Filter_num, INT8U ext, INT32U Data)
INT8U res = MCP_OK;
delay(10);
if(res > 0)
delay(10);
return res;
switch( Filter_num )
case MCP_RXF0:
mcp_writeid(MCP_RXF0SIDH, ext, Data);
break;
case MCP_RXF1:
mcp_writeid(MCP_RXF1SIDH, ext, Data);
break;
case MCP_RXF2:
mcp_writeid(MCP_RXF2SIDH, ext, Data);
break;
case MCP_RXF3:
mcp_writeid(MCP_RXF3SIDH, ext, Data);
break;
case MCP_RXF4:
mcp_writeid(MCP_RXF4SIDH, ext, Data);
break;
case MCP_RXF5:
mcp_writeid(MCP_RXF5SIDH, ext, Data);
break;
default:
res = MCP_FAIL;
if(res > 0)
delay(10);
return res;
delay(10);
return res;
INT8U MCPCAN::setMsg(INT32U id, INT8U ext, INT8U len, INT8U rtr, INT8U *pData)
int i = 0;
can_ExtFlg = ext;
can_ID = id;
can_Dlc = len;
can_Rtr = rtr;
for(i = 0; i < MAX_MESSAGE_LENGTH; i++)
can_Dta[i] = pData[i];
return MCP_OK;
INT8U MCPCAN::setMsg(INT32U id, INT8U ext, INT8U len, INT8U *pData)
int i = 0;
can_ExtFlg = ext;
can_ID = id;
can_Dlc = len;
can_Dta[i] = *(pData+i);
return MCP_OK;
INT8U MCPCAN::clearMsg()
can_ID = 0;
can_Rtr = 0;
can_ExtFlg = 0;
can_filhit = 0;
can_Dlc = 0;
for(int i = 0; i<can_Dlc; i++ )
can_Dta[i] = 0x00;
return MCP_OK;
INT8U MCPCAN::sendMsg()
INT8U res, txindex;
uint16_t uiTimeOut = 0;
do {
res = mcp_getNextFreeTXBuf(&txindex);
uiTimeOut++;
} while (res == MCP_ALLTXBUSY && (uiTimeOut < TIMEOUTVALUE));
if(uiTimeOut == TIMEOUTVALUE)
return CAN_GETTXBFTIMEOUT;
uiTimeOut = 0;
mcp_writecanMsg( txindex);
mcp_starttransmit( txindex );
do
uiTimeOut++;
res = mcp_readRegister(txindex);
res = res & 0x08;
}while(res && (uiTimeOut < TIMEOUTVALUE));
return CAN_SENDMSGTIMEOUT;
return CAN_OK;
* @brief: send the remote requestion message.
* @parameter:
@id:
the message id num.
@ext:
@len:
the len of the data to send.
@rtr:
the flag of the remote requestion. if rtr = 1, the frame seem as the remote requestion frame , or the frame is the normal data frame..
@buf:
the data to send.
INT8U MCPCAN::sendMsgBuf(INT32U id, INT8U ext, INT8U rtr, INT8U len, INT8U *buf)
setMsg(id, ext, len, rtr, buf);
return sendMsg();
* @brief: send one data frame.
* @parameter:
@id:
the message id num.
@ext:
@len:
@buf:
the data to send.
INT8U MCPCAN::sendMsgBuf(INT32U id, INT8U ext, INT8U len, INT8U *buf)
setMsg(id, ext, len, buf);
return sendMsg();
INT8U MCPCAN::readMsg()
INT8U status, res;
status = mcp_readStatus();
if ( status & MCP_MESGE_RXB0_MSK )
mcp_readcanMsg( MCP_RXBUF_0); //0x61
mcp_modifyRegister(MCPCANINTF, MCP_RX0IF, 0);
res = CAN_OK;
else if ( status & MCP_MESGE_RXB1_MSK ) //message in rx buf1
mcp_readcanMsg( MCP_RXBUF_1);
mcp_modifyRegister(MCPCANINTF, MCP_RX1IF, 0);
res = CAN_OK;
else if (status & MCP_MESGE_RXB01_MSK)
res = CAN_OK;
else
res = CAN_NOMSG;
return res;
* @brief: read one data frame from the cache in inner can controler.
* @parameter:
@len:
the len of the data to read.
@buf:
the data out from the Can controler store into the buf.
INT8U MCPCAN::readMsgBuf(INT8U *len, INT8U *buf)
INT8U res, i;
res= readMsg();
if (res == CAN_OK) {
*len = can_Dlc;
for( i = 0; i<can_Dlc; i++) {
buf[i] = can_Dta[i];
} else {
*len = 0;
return res;
* @brief: read one data frame from the cache in inner Can controler with the indicated ID, if Can controler has not cached the ID's Frame
the return value is not CAN_OK.
* @parameter:
@ID:ID number.
@len:
@buf:
* @return the status. if success, return MCP_OK. or this read operation is failed.
INT8U MCPCAN::readMsgBufID(INT32U *ID, INT8U *len, INT8U *buf)
INT8U ret;
ret = readMsg();
if (ret == CAN_OK) {
*len = can_Dlc;
*ID = can_ID;
for(int i = 0; i<can_Dlc && i < MAX_MESSAGE_LENGTH; i++) {
} else {
*len = 0;
return ret;
* @brief: check whether data is cached by Can controler.
* @parameter:
@ID:ID number.
@len:
@buf:
* @return: if there are some data received by Can controller. the return value is CAN_MSGAVAIL, or CAN_NOMSG.
INT8U MCPCAN::checkReceive(void)
INT8U res;
res = mcp_readStatus();
if ( res & MCP_MESGE_NO_MSK )
return CAN_MSGAVAIL;
else
return CAN_NOMSG;
* @brief: check whether there is the control error on the Can bus line.
* @parameter: void
* @return: if control error don't occur, return CAN_OK, or return CAN_CTRLERROR.
INT8U MCPCAN::checkError(void)
INT8U flag = mcp_readRegister(MCP_EFLG);
if ( flag & MCP_EFLG_ERRORMASK )
return CAN_CTRLERROR;
else
return CAN_OK;
* @brief: get the id of the data cached in Can controller currently.
* @parameter: void
* @return: return the id number.
INT32U MCPCAN::getCanId(void)
return can_ID;
* @brief: tell whether the current data frame buffered in Can controller is remote requestion frame.
* @parameter: void
INT8U MCPCAN::isRemoteRequest(void)
return can_Rtr;
* @brief: tell whether the current data frame buffered in Can controller is extended frame.
* @parameter: void
INT8U MCPCAN::isExtendedFrame(void)
return can_ExtFlg;
I also tried using I2C instead I beleive this is supported, I couldn’t find a DFRobot library for this so I used this one Logan Labs I2C CAN Library which is designed for the same CAN IC’s. The initialisation worked for this however no can messages were transmitted. Error message 2 is being output which stands for CAN_FAILTX.
/* send a frame from can bus
support@longan-labs.cc
CAN Baudrate,
#define CAN_5KBPS 1
#define CAN_10KBPS 2
#define CAN_20KBPS 3
#define CAN_25KBPS 4
#define CAN_31K25BPS 5
#define CAN_33KBPS 6
#define CAN_40KBPS 7
#define CAN_50KBPS 8
#define CAN_80KBPS 9
#define CAN_83K3BPS 10
#define CAN_95KBPS 11
#define CAN_100KBPS 12
#define CAN_125KBPS 13
#define CAN_200KBPS 14
#define CAN_250KBPS 15
#define CAN_500KBPS 16
#define CAN_666KBPS 17
#define CAN_1000KBPS 18
#include <Wire.h>
#include "Longan_I2C_CAN_Arduino.h"
I2C_CAN CAN(10); // Set CS pin
void setup()
Serial.begin(115200);
while (CAN_OK != CAN.begin(CAN_500KBPS)) // init can bus : baudrate = 500k
Serial.println("CAN BUS FAIL!");
delay(100);
Serial.println("CAN BUS OK!");
unsigned char stmp[8] = {1, 2, 3, 4, 5, 6, 7, 0};
int cnt = 0;
void loop()
stmp[7] = cnt++;
if(cnt > 100)cnt = 0;
Serial.println(CAN.sendMsgBuf(0x01, 0, 8, stmp));
delay(5); // send data per 100ms
// END FILE
