A friend, a retired electrician, wants to experiment with robotics and control of stepper motors. I have Pi 5, Pi 4, and Pi Zero 2 plus breadboards jumper leads but nothing with a stepper motor and no clue what to do next. My experience is pushing a resistor and LED into the breadboard. What project should we tackle first for least cost and least learning?
As a kid, I used meccano. Adding stepping motors and programming would have been superb fun but I think the best chip back then was the Intel 4004.
First get a stepper motor and a driver board and a good power supply. The nature of stepper motors is they are drawing current all the time, the usual Pi supply is not good enough.
This is a good one but expensive, cheaper ones are just not worth it.
This driver board should work if connected correctly and has a connection for the power to the stepper motor. GPIO interface to Pi. But there are many others some using I2C so not as many connecting pins. VMOT can be 6V to 30V, the linked stepper motor works of 12V 0.33A
Care should be taken to connect the wires in the correct phase between the stepper motor and the driver board.
Once you have an idea how the motor works and the different step rates you could look for a project to make something move.
PS: 12V 1A or 2A plug pack power supply could be used for the VMOT connection.
@Peter181516 Good choice of parts.
Never had a problem with Micro Metal Gear motors, they work very well.
The Makerverse range is very good too. I have used that board to drive two motors in an RC cart but not a stepper motor. Its just a matter of getting the software correct.
Hi Peter, quite a while ago I came from the programming side wanting to play with robotics via BOE-BOT and Raspberry Pi v1 when that was released. Not knowing anything much about electronics I bought several Raspberry Pi HATs and Bonnets which make it real easy to add various types of devices since half the interfacing is done for you.
Raspberry Pi was pretty much designed for education, and the RaspberryPi website has lots of resources, including a monthly magazine (and back-issues) which you can download as a PDF for free - though you may have to wait a few weeks after the hardcopy is published. Issue 150 included an overview of 150 Projects & People which might give some inspiration
Core Electronics stocks many Raspberry Pi boards and accessories from Raspberry Pi, Adafruit, DFRobot, and many of the reputable makers. I have bought items from overseas, but decided the slightly higher price from Core is offset by convenience of a one-stop-shop with quick delivery and local support.
I also personally prefer breakout boards and i2c communications to quickly and easily add a component such as a Capacitive Touch Sensor, Temperature/Humidity sensor or Tripple-axis Accelerometer to a breadboard, rather than attempting to solder the individual components.
