@Robert93820 here is my plan to use a single push button to latch the lamp. I’ve got a jk flip flop to handle the latching and my button is just a clock that’s flipping and flopping Q and Q-.
The button here is this tiny jaycar button. It’s max is 12v so I could use it in series with the lamp but I felt that would be flying too close to the sun. I need 5v circuitry anyway for my LS series ICs.
Hey @Robert93820
Wondering if you can improve this idea a little.
I’m glad this circuit is working.
However it would be ideal if the lamp could be on the other side of the transistor.
Imagine wiring this house. As it stands each lamp would need it’s own return path to the transistor.
However if the lamp was on the other side of the transistor all the lamp’s returns could combine at ground. That would making wiring the house soo much easier which is good because we have to work with conductive tape.
I looked at using a PNP transistor because that would put the collector and thus the lamp towards ground. However I think I’d be tying the base to 12v and so my 74ls73 would need some kind of voltage protection. It all got away from me so I settled for the NPN design I felt more comfortable with.
Not quite correct. The lamp will drop 12V so you would have one side of the LAMP at ground but everything on the other side would be something like 12V above ground.
That IC is only good for 5.5V so I think you are stuck with NPN switching to ground. You can’t have the lamp in the emitter circuit as then the base would have to go to about 12.6V to turn it on.
I don’t think the wiring is any worse off this way. You either common all the grounds as you suggest and return that to some common point or you common all the lamps on the one side and return that to 12V. Same amount of wiring. You will need a transistor with a healthy hfe as I don’t think this IC will source much current.
Just a thought here, and I am more then happy to be wrong Depending on the quality of the push button, you will get some level of “bounce” as it makes contact, breaks contact many times as its getting pressed down. As such, the JK may clock more then once per press, resulting on the lights may be on may be off. By adding a capacitor in parallel with the 10K, should give a power reserve to hold it High for an extended period.
i.e. Rapid charge when button makes contact, then slow discharge via the 10K resistor when the contact is broken. So any rapid contact/no-contact could be absorbed by the cap. (or is there some level of anti-bounce in the JK?)
@Robert93820
Reading the datasheet on the 74LS74 I have 20ma which I’m hoping is enough.
I already have these so I’m keen to use them up.
If they don’t work I’ll source some 74HC73s
Straight from TI data sheet.
one more thing. The 74lLS and HC73 are J/K flip flops with different logic that the 74LS74 which is a D flip flop and does not have a “toggle” set up as does the '73 so won’t work as you expect.
I wonder what the difference between recommended operating conditions and electrical characteristics [in] recommended operating conditions is supposed to be.
Weird.
I actually failed to note that the measurement for Iih is in ua not ma so even so it’s tiny.
I think I need to measure
P.S. I have a few 74HC74s lying around so I can try those as well.
I can buy more if they’re joyful
As I said above, different flip flop and I am not sure if they are even pin compatible. I think VCC and Gnd might be different for a start. Please check before powering up.
I’ve tested and swapped to an 74HC73 JK flip flop.
It does activate the transistor but depending on the transistor I need to slide the value of R4.
I’m going to measure current soon when I fix the fuse on my multi-meter.
I’m also going to add a relay.
The relay is not necessary but it sells the illusion of the light switch with a mechanical click.
The circuit on the whole might be slightly more robust but testing will tell.
Lastly @Michael99645 I’ve added a nice long de-bouncing circuit because those halogen lights hate being switched off and on. Hopefully ~10seconds is long enough to communicate to the user that you’re not supposed to mash the button. In this case the user is a toddler so … I might have to extend that time.
When doing this DO NOT use the mA range on a DMM. The internal meter resistance is kikely to be more than the 3k3 resistor and will be in series with it. I am speaking about base current here but much the same for collector current .
The most non invasive way to do this without special current probes is to measure the voltage drop across the 3k3 resistor and the relay coil and calculate the current from this. That way you are getting the circuit in true operating conditions without it being modified by the meter internal resistance…Cheers Bob
Ahhh yeah noted.
Clever solution. I’ve picked up the basics of calculating the values of circuits from youtube and reading a few text books. Still I’ve never had to study for a test so I make mistakes. Can I give it a go and then post my results here and then maybe you and the community can red pen my calculations?
Hi Pix
Ohm’s law and basic arithmetic will do the trick. I won’t tell you. I will let you make any mistakes (if any) then correct you. That way I feel you will learn more.
You will have to measure the resistance of the relay coil or the data sheets should be close enough. Use 1% or better base resistor for closer results.
