I have the following motor:
https://www.oyostepper.com/goods-31-Nema-17-Stepper-Motor-Bipolar-18-deg-13Ncm-184ozin-1A-35V-42x42x20mm-4-Wires.html
And the following driver:
https://www.oyostepper.com/goods-822-Digital-Stepper-Driver-for-Nema-14-17-23-Stepper-Motor-Y-Series-03-22A-DC18V-36V.html
I’ve red a lot about stepper, not sure I understood everything, but it seems that I can power this motor using any voltage I want and the actual voltage limit comes from the driver.
The driver works with 8 - 45 volts.
What I don’t understand is what is the minimum and the optimal power supply needed ?
Is a 12v 1A power supply from an old router will power it (without any load) ?
Should I buy 24v power supply ? if so, how much current should it support ? I guess there is no need for more than 2.2A as the driver can’t cope with higher current.
And If that is the case, to get the maximum torque should I look for a 45V power supply ?
I’d really appreciate if someone could clarify this things
