A few little thing while we wait for the guru’s to give some feedback.
Any photos of your write hook up can help. Also the code snippets to setup and send commands.
Having a quick look at the guide I see it uses 2 UARTS, 1 for the AT Commands on pings TX1, RX1 (PA9/10). then the UART for that data PA2/3.
So for that AT command it will be PA9/10. Check the cross over. Normally you would connect RX-TX and TX to RX, but sometimes its could be RX-RX and TX-TX, no harm in trying a swap over (from the photos it looks like the normal RX-TX).
Check the baud rate, its should be 115200
Thank you for your help! This is our wiring. The code is exactly cut and pasted from the arduino ide version posted in the tutorial. We tried switching the rx/tx going rx to rx, tx to tx with not luck.
To me it looks like you have the UART Pins for data output connected, but to use the AT commands you need to use the UART Pins for AT Commands (the other side)
Thank you! The picture I took was my last shot at hooking this up in desperation, I tried using the other pins. With the correct connections as you pointed out, I again hooked up to AT command pins with the same result in the code. Please let me know if you have any other suggestions. Do I need to declare rx/tx pins on the esp32 dev board in the code?
full code with serial monitor result:
void setup() {
// Initialize USB Serial for debugging
Serial.begin(115200);
while (!Serial) {
; // Wait for USB serial port to connect
Serial.println("Starting board configuration...");
// Initialize hardware UART on pins 0 (RX) and 1 (TX) for UWB communication
Serial1.begin(115200);
delay(2000); // Give some time for everything to get ready
// Send configuration command
Serial.println("Sending AT+SETCFG command...");
Serial1.print("AT+SETCFG=0,0,1,1\\r\\n");
delay(1000);
// Check for response
if (Serial1.available()) {
String response = Serial1.readString();
Serial.println(response);
delay(3000);
// Save configuration
Serial.println("Sending AT+SAVE command...");
Serial1.print("AT+SAVE\\r\\n");
delay(3000);
// Get current configuration to verify
Serial.println("Sending AT+GETCFG command...");
Serial1.print("AT+GETCFG\\r\\n");
delay(100);
void loop() {
I prefer to do that as then I know exactly what pins its using. Please not I am not an Arduino user, so I cant tell you the commands.
From your code above
t seems its trying to use GPIO pin 0/1, which to me makes no sense at all.
Normally Serial 0 is the main programing/debug serial port the also goes via the USB, which would be your serial 0.
So maybe something like
Serial1.begin(115200, SERIAL_8N1, RXPIN, TXPIN);
where RXPIN and TXPIN would be you gpio for where you want it. (GPIO 16/17 by the look of your wiring) but that seems to be labeled as UART2 RX/TX. In theory that should be OK as long as UART2 is not currently enabled.
Hey Michael, are you currently following the steps from the below tutorial?
If you are, I think the pins you’re using are incorrect. Based on the pinouts for the dev board below, you would be using UART 2 in your setup which probably is not the default configuration:
Could you try using the pins labelled GPIO1 and GPIO3 in the diagram above. Since they’re labelled as UART0 they’re more likely to be the default UART pins.
Hi Jane, thank you for the reply! We are following the steps in the tutorial. I tried with the other pins this morning. With the rx going to the tx I received the error below. When I ran the rx to rx and tx to tx is loaded, but I received the same message as befor in the serial monitor. Thank you again for your help!
If using UART0 then you most likely need to remove the connections during flashing as the USB->UART for programming will be via UART0
After you flash the device you can try to re-connect, but you wont be able to monitor the serial output. I would use UART1 or 2 and device the pins you what to use as RX/TX.
Thank you again for all your help. We decided to purchase an arduino r4 and were able to get throught the provided tutorial and have the distance between the the anchor and tag! Although this may seem basic… The students would now like to do something with the distance data. Are there any examples of how we could illuminate some LEDs bas on a distance range? For example, it the distance is between the anchor and tag is between 5 and 10 meters apart turn on an LED. Thanks again for all your efforts, it is really appreciated!
Hi Jane. Thank you so much again for your help. The studnets will be exicited to try the code you provided and will defininetly help expand their and my knowledge, as this level of coding is out of area of expertise… I will let you know how we are making out. Thanks again!
As a comment… once you have the distance measuing device feeding values back, one way to to print those to the terminal window. Then have it detect someone at the start of the “detect zone” and record that value. Next have it detect someone at the end of the “detect zone” and record that value.
Now that you know the two values that the unit will feed you for the start and end…
psedude code
if ((measuredDistance >= StartRange) && (measuredDistance <= EndRange)) {
// Do something.
// eg make a pin go high to trigger something...
the reason I like this apprach is it is very practical. So if the unit is not calibrated to give the correct “meters” it can still be used to detect a range; and you/the students can see how testing the range first can help “tune” what you want to do.
Thanks Jane. Students have headed home for the holiday, so I’m sure they will be back at it when we return. I again really appreciate your help!
Mike
They did have a few minutes yesterday to test the code and said they were getting an error with one of the brackets in the loop. I did not have a chance to see it so I’m not sure. But again, I really appreciate the help!
