DC-DC Buck Converter 6~14V to 5V/8A (DFR0753)
This is a placeholder topic for “DC-DC Buck Converter 6~14V to 5V/8A” comments.
This 40W high power DC-DC Buck converter offers a 6~14V input voltage range and up to 5V/8A output. Featuring a small body, high conversion ratio, strong heat dissipation…
Hi
Will this buck output be enough to run raspberry pi 4/5?
Hi Glenn,
Technically it should be. The Pi 4 and 5 both ask for 5.1V so you may experience some low power warnings. Power in is about equal to power out so also consider your source here.
Hi Glenn,
Welcome back :smiley:
Jacks spot on the money, the Pi 4 is more than happy to be powered up a few different ways (5V through the pins, or USB).
But the Pi 5 is a bit more tempermental, if powered up with a non-PD source (this board, even though it can, in theory, deliver up to 8A) will still limit the USB output current as the power source hasnt communicated its max output.
With a bit more information about your project we should be able to help out a bit more!
Hi Liam and Jack
I’d like to power via 12v from a vehicle. There used to be an adjustable buck but I couldn’t see it the website.
Glenn Trotman
Hi Glenn,
Ahhh sounds like a great application for this board :smiley:
By chance was this the buck module you were looking for? DC-DC Adjustable Step-down Module 5A 75W | Core Electronics Australia
A product like the Pimoroni Wide Input SHIM - Kit | Core Electronics Australia
Would be great for this!
(Of if you need an RTC: Witty Pi 4 HAT - RTC & Power Management for Raspberry Pi | Adafruit ADA5704 | Core Electronics Australia)
can i use this for arduino r4?
