Hi team! When the PiicoDev MPU6050 was retired and there was no substitute available from CE I managed to acquire one elsewhere. I see it has been now replaced by the LIS3DH and I was wondering if there are any differences between the two products.
Is the LIS3DH any better? I’m mostly interested in using an accelerometer/motion sensor for tap (and double-tap) detection.
Other than the obvious change in the chipset being used there arent too many other differences!
The MPU6050 is a Maker favourite accelerometer and is super widely used - though the silicon shortage made it super hard to come by.
A majority of the specificications are the same, both feature 2,4,8, 16g ranges with a refresh rate up to 200Hz.
However, there are some bonuses of the LIS3DH if you take a trawl through the datasheet for the IC the tap and other functions are actually part of the silicon! With direct registers providing the output.
Whereas the MPU-6050 would require the microcontroller to interpret those measurements.
