I need to run 4 separate 6500mm lengths of addressable LED each connected to a distance sensor and run through a rasperry pi from a 240V generator. The LED will react based on how far the object is away from the sensor. The sensor needs to be accurate between 0m and 3m.
Are the products below appropriate and what other components do i need?
