I have a Senztek AlphaStat digital thermostat controller. Sensor probe keeps failing in the dry well because moisture build up in the dry well.
I came across your website and interested in ds18b20 waterproof sensor probe. The sensor probe comes with 3 wire connections while my thermostat has 2 wire connection. Which 2 wire from your sensor probe to connect to my thermostat 2 wire connection?
Spec from thermostat:
Sensors
Display Range -20~+139°C [-4~+282°F]
Control Range -40~+150°C [-40~+302°F]
PVC Sensor (tank and inlet) -40~+105°C [-40~+221°F]; 4mm [0.16 inch] Diameter, UV
Resistant.
Teflon Sensor (roof) -40~+250°C [-40~+482°F] peak; 4mm [0.16 inch] Diameter, UV
Resistant.
Accuracy +/-1°C @ 25°C; +/-1.8°F @ 77°F
manual:
Thank you.
