Hi all,
I’m seeking advice about sensor hardware options regarding a project.
The project is to measure the temperature and water level of a hot water tank. This is for a semi-commercial environment where the hot water is heated to 90 degrees Celsius for sanitisation purposes.
I plan to connect sensors to a Raspberry Pi Pico W or ESP32 base microprocessor running ESP-Home to easily integrate into Home Assistant for further data analysis, presentation, automation, etc.
Possible sensors could be…
Questions I have are:
- Is one DS18B20 temperature sensor noted better than the other for my use case?
- Will these sensors, including the water level sensor, work at 90 degrees Celsius?
- Any thoughts on an ultrasonic method to measure tank water level like this option?:
Weatherproof Ultrasonic Sensor with Separate Probe | Buy in Australia | SEN0208 | DFRobot | Core Electronics as used in this project Water Tank Level Sensor - Tutorial Australia
or perhaps:
EPTTECH TLC2206 Tuya Smart Life Mobile APP Wireless WiFi Remote Ultrasonic Real-time Reminder Contactless Outdoor Waterproof IP67 Continuous Accurate Liquid Water Oil Fuel Level Tank Monitor Sensor : Amazon.com.au: Home Improvement
for easy integration with Home Assistant via Tuya.
Any advice is welcome.
