The goal for this project was to make an easy-to-use display that doesn’t need power all of the time!
Parts
- PiicoDev Transceiver
- Badger 2040
- A Pico
- PiicoDev Expansion Board
- Misc parts, USB cables, power supply, PiicoDev cables
Instructions
Plug the transceivers into the Pico and Badger boards
Plug both boards into your computer
Set Thonny up, making sure that more than 1 window is enabled (Tools > Options > General > Allow only a single Instance - ensure this is unticked)
Upload the code below:
For the Badger:
# Listen for LED control messages
# Valid messages set the state of the on-board LED
from PiicoDev_Transceiver import PiicoDev_Transceiver
from PiicoDev_Unified import sleep_ms
from machine import Pin
import badger2040
radio = PiicoDev_Transceiver(bus=0,sda=Pin(4),scl=Pin(5),freq=100000)
display = badger2040.Badger2040()
display.led(128)
display.update_speed(badger2040.UPDATE_FAST)
display.font("bitmap8")
display.thickness(1)
display.pen(0)
#name, size, thickness
font = ("sans", 2, 3)
# Font constants
display.font(font[0]) #name
display.thickness(font[2]) #thickness
# Max length should be handled by the sending device
str_lst = ['','','']
def draw_text_handler():
display.pen(0)
display.text(str_lst[0], 0, 24, font[1])
display.text(str_lst[1], 0, 72, font[1])
display.text(str_lst[2], 0, 108, font[1]/2)
display.update()
def rcv_str_handle(str_inp):
if str_inp.find(':') is not -1:
multi_ln_str = str_inp.split(':')
for split_line_strs in multi_ln_str:
str_line_handle(split_line_strs)
else:
str_line_handle(str_inp)
def str_line_handle(strs):
global str_lst
strs = strs.split(',')
#print(strs)
str_lst[int(strs[0])] = strs[1]
print('Running')
while True:
if radio.receive():
message = radio.message
# print(message)
display.pen(15)
display.clear()
sleep_ms(1500)
rcv_str_handle(message)
draw_text_handler()
sleep_ms(50)
For the Pico
radio = PiicoDev_Transceiver()
radio.send("0,Wireless:1,Updating:2,Name Badge")
- Customise the text you want to display!
The line that you want to update is specified by the number, a comma then the text
Line one and two use a larger font and can display 7ish characters whereas the third uses a smaller font holding around 14
Any questions or queries lemme know!
