Hello, James, and Jeff…
You guys are the best!!! !! I found it had been selected for an Attiny85. I had neglected to change it. The error, was indeed mine.
Sorry to have taken up your valuable time on this. Sometimes, my old man brain needs a kick start, and you did it… again… lol!!!
THANK YOU SO VERY MUCH!!!
Taz…
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Kims\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Kims\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Kims\Documents\Arduino\libraries -fqbn=ATTinyCore:avr:attinyx5:LTO=enable,TimerClockSource=default,chip=85,clock=8internal,eesave=aenable,bod=disable,millis=enabled -ide-version=10819 -build-path C:\Users\Kims\AppData\Local\Temp\arduino_build_862933 -warnings=all -build-cache C:\Users\Kims\AppData\Local\Temp\arduino_cache_807794 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.micronucleus.path=C:\Users\Kims\AppData\Local\Arduino15\packages\ATTinyCore\tools\micronucleus\2.5-azd1b -prefs=runtime.tools.micronucleus-2.5-azd1b.path=C:\Users\Kims\AppData\Local\Arduino15\packages\ATTinyCore\tools\micronucleus\2.5-azd1b -prefs=runtime.tools.avr-gcc.path=C:\Users\Kims\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Kims\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\Kims\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.avrdude-6.3.0-arduino18.path=C:\Users\Kims\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -verbose I:\1A CTC SIGNAL SCHEMATICS\CONTROL POINT FIRMWARE\Cotrol_point_Firmware\Cotrol_point_Firmware.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Kims\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Kims\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Kims\Documents\Arduino\libraries -fqbn=ATTinyCore:avr:attinyx5:LTO=enable,TimerClockSource=default,chip=85,clock=8internal,eesave=aenable,bod=disable,millis=enabled -ide-version=10819 -build-path C:\Users\Kims\AppData\Local\Temp\arduino_build_862933 -warnings=all -build-cache C:\Users\Kims\AppData\Local\Temp\arduino_cache_807794 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.micronucleus.path=C:\Users\Kims\AppData\Local\Arduino15\packages\ATTinyCore\tools\micronucleus\2.5-azd1b -prefs=runtime.tools.micronucleus-2.5-azd1b.path=C:\Users\Kims\AppData\Local\Arduino15\packages\ATTinyCore\tools\micronucleus\2.5-azd1b -prefs=runtime.tools.avr-gcc.path=C:\Users\Kims\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Kims\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\Kims\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -prefs=runtime.tools.avrdude-6.3.0-arduino18.path=C:\Users\Kims\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18 -verbose I:\1A CTC SIGNAL SCHEMATICS\CONTROL POINT FIRMWARE\Cotrol_point_Firmware\Cotrol_point_Firmware.ino
Using board ‘attinyx5’ from platform in folder: C:\Users\Kims\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2
Using core ‘tiny’ from platform in folder: C:\Users\Kims\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2
Detecting libraries used…
“C:\Users\Kims\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB “-IC:\Users\Kims\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\cores\tiny” “-IC:\Users\Kims\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\variants\tinyX5” “C:\Users\Kims\AppData\Local\Temp\arduino_build_862933\sketch\Cotrol_point_Firmware.ino.cpp” -o nul
Generating function prototypes…
“C:\Users\Kims\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB “-IC:\Users\Kims\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\cores\tiny” “-IC:\Users\Kims\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\variants\tinyX5” “C:\Users\Kims\AppData\Local\Temp\arduino_build_862933\sketch\Cotrol_point_Firmware.ino.cpp” -o “C:\Users\Kims\AppData\Local\Temp\arduino_build_862933\preproc\ctags_target_for_gcc_minus_e.cpp”
“C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags” -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives “C:\Users\Kims\AppData\Local\Temp\arduino_build_862933\preproc\ctags_target_for_gcc_minus_e.cpp”
Compiling sketch…
“C:\Users\Kims\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++” -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=attiny85 -DF_CPU=8000000L -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB “-IC:\Users\Kims\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\cores\tiny” “-IC:\Users\Kims\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\variants\tinyX5” “C:\Users\Kims\AppData\Local\Temp\arduino_build_862933\sketch\Cotrol_point_Firmware.ino.cpp” -o “C:\Users\Kims\AppData\Local\Temp\arduino_build_862933\sketch\Cotrol_point_Firmware.ino.cpp.o”
Cotrol_point_Firmware:26:18: error: ‘A5’ was not declared in this scope
const int CODE = A5; // Code Button on Dispatch Panel(INPUT)
I:\1A CTC SIGNAL SCHEMATICS\CONTROL POINT FIRMWARE\Cotrol_point_Firmware\Cotrol_point_Firmware.ino:26:18: note: suggested alternative: ‘A3’
A3
Cotrol_point_Firmware:27:30: error: ‘A4’ was not declared in this scope
const int LB_SIGNAL_SELECT = A4; // Leftbound Signal Select on Dispatch Panel(INPUT)
I:\1A CTC SIGNAL SCHEMATICS\CONTROL POINT FIRMWARE\Cotrol_point_Firmware\Cotrol_point_Firmware.ino:27:30: note: suggested alternative: ‘A3’
A3
exit status 1
Now, This usually means I haven’t declared it as an integer. I am using the Spence - Konde core.
Here is the screen shots requested. Let me know if you need to view more.
