Affectionately dubbed “Fairy Lights” for their similar appearance, these addressable RGB LED string lights are a great way to light up any project with no soldering…
I can understand your confusion regarding those fairy lights as there’s a bit of contradictory information out there regarding them.
The datasheet we’ve been provided for them lists the interface as SPI, but it’s clearly not a standard implementation of SPI with only 3 wires.
SparkFun has these lights listed as part of their WS2812 hookup guide which is probably the most common style of individually addressable RGB LEDs out there (also known by the trade names GlowBits and NeoPixels) and those lights do use a 1-wire data interface with the other two being power and ground. https://learn.sparkfun.com/tutorials/ws2812-breakout-hookup-guide#pinout
I’m fairly confident these LEDs should be individually addressable using the NeoPixel library but I’ll run a quick test with them on the bench later and report back.
I’ve finished a bench test with those fairy lights and my suspicion was correct, they appear to be WS2812 chips or equivalent so any NeoPixel or GlowBit library should be able to drive them.
I’ll contact our supplier later this morning as the stock I have here in the warehouse is definitely mislabelled. The fairy lights I tested were marked with WS2811&SK6812 which can’t be correct as WS2811 is the 12volt version of those chips. SK6812 is a drop in replacement for the common WS2812 though, as they are equivalent and a minor upgrade in terms of colour consistency across different supply voltages.
I’ll chase up these discrepancies and the incorrect datasheet with our supplier this morning and get the product page updated to make it clear these are WS2812, NeoPixel-equivalent strips.
According to the thread above this was going to be done August last year, 15 months ago.
Could Core clarify please as I could get interested in these.
Glad to hear you got them working after finding the comments! Sorry for the mix-up on the product page
Keen to see them running
Both you and Bob are absolutely right, our supplier made some minor adjustments to the product page that I’ve just imported (all of the notes to come back and fix it up were in place).
The new changes ought to keep makers projects moving quickly!
