Hi Bryce ! Yes I will try to do that ! This is a program where I did a screenshot! Thank you, have a good day
Geophonino-GUI-master.zip (5.4 KB)
/*Geophonino is an Arduino-based seismic recorder for vertical geophones.
The computer programming consists of:
Geophonino.ino: The Arduino Sketch.
GuiGeophonino.pde: The user interface developed by using Processing software.
Last update: 21/10/2015
Email contact: jl.soler@ua.es, juanjo@dfists.ua.es*/
import controlP5.*;
import processing.serial.*;
/*Initialization of variables*/
Serial myPort;
String val; //store data received in the serial port
boolean firstContact = false; //is false while Processing isn't connected to Arduino
ControlP5 cp5; //cp5 printer for GUI
DropdownList ddlCom,ddlGain,ddlSr; //DDL Drop Down List objtects
PFont fontTit = createFont("arial",20);
PFont fontTex = createFont("arial",12);
PFont fontTexMini = createFont("arial",10);
Textfield status; //Text field for notifications to the user
int myColorBackground = 255; //Default Background
int state=1; //1-Conf. connection 2-Conf. acquisition 3-Ready for data acquisition 4-Acquiring data 5-Reciving file 7-File Recived
OutputStream OutputFileRecived; //Writer for file received over serial port
byte [] FileBuffer=new byte[0];
String folder=null; //Folder when the file downloaded from Arduino will be saved
String overwriteFile="N"; //When selected name already exist, user can overwrite it. By default, N=false.
/* Variables progress bar */
int count=0;
int ini=0;
Integer duration=0;
Integer tamFile=0;
/* End variables progress bar */
void setup() {
size(800,500); //Window size
cp5 = new ControlP5(this);
// Print Status bar
cp5.addTextlabel("textWarnings").setText("Current status: ")
.setPosition(50,470).setColorValue(0).setFont(fontTex);
cp5.addTextfield("Status")
.setPosition(150,470)
.setSize(550,20)
.setFocus(true)
.setFont(fontTex)
.setColorValue(255)
.setColorBackground(color(200, 200, 200));
status = ((Textfield)cp5.getController("Status"));
status.setValue("Welcome Geophonino configuration");
cp5.addTextlabel("Connection").setText("1º Connection configuration")
.setPosition(50,20).setColorValue(0).setFont(fontTit) ;
cp5.addTextlabel("txtSerial").setText("Select the Geophonino connection port")
.setPosition(50,60).setColorValue(0).setFont(fontTex);
ddlCom = cp5.addDropdownList("serial").setPosition(270, 75);
for (int i = 0; i < Serial.list().length; i = i+1) {
ddlCom.addItem(Serial.list()[i], i+1);
if (Serial.list().length==0)
status.setValue("Error, COM Port not detected, connect Geophonino and press CONNECT... button.");
customizeDl(ddlCom);
cp5.addButton("Connect...")
.setValue(0)
.setPosition(380,60)
.setSize(100,14)
.setId(1);
cp5.addButton("Refresh port list")
.setValue(0)
.setPosition(500,60)
.setSize(100,14)
.setId(2);
cp5.addTextlabel("ConfAcquisition").setText("2º Data acquisition configuration")
.setPosition(50,100).setColorValue(0).setFont(fontTit) ;
cp5.addTextlabel("Comment").setText("Set configuration parameters and press SEND CONFIGURATION button")
.setPosition(50,140).setColorValue(0).setFont(fontTex);
cp5.addTextlabel("txtNameFile").setText("File name: ")
.setPosition(50,180).setColorValue(0).setFont(fontTex);
cp5.addTextlabel("WarningNameFile").setText("(max. 8 characters)")
.setPosition(240,180).setColorValue(0).setFont(fontTexMini);
cp5.addTextfield("fileName")
.setPosition(135,178)
.setSize(100,18)
.setFocus(true)
.setFont(fontTex)
.setColorValue(255)
.getCaptionLabel().hide();;
cp5.addTextlabel("txtDura").setText("Duration (s): ")
.setPosition(350,180).setColorValue(0).setFont(fontTex);
cp5.addTextfield("dura")
.setPosition(430,178)
.setSize(100,18)
.setFocus(true)
.setFont(fontTex)
.setColorValue(255)
.setColorCaptionLabel(200)
cp5.addButton("Send configuration")
.setValue(0)
.setPosition(50,260)
.setSize(100,14)
.setId(3);
cp5.addButton("Get configuration")
.setValue(0)
.setPosition(180,260)
.setSize(100,14)
.setId(4)
.setVisible(false);
cp5.addTextlabel("txtBits").setText("Amplification:")
.setPosition(50,220).setColorValue(0).setFont(fontTex);
ddlGain = cp5.addDropdownList("x").setPosition(135, 235);
ddlGain.addItem("0.5", 1);
ddlGain.addItem("1.0", 2);
ddlGain.addItem("2.0", 3);
customizeDl(ddlGain);
cp5.addTextlabel("txtSps").setText("Sampling Rate (ms/sps):")
.setPosition(290,218).setColorValue(0).setFont(fontTex);
ddlSr = cp5.addDropdownList("ms/sps").setPosition(430, 235);
ddlSr.addItem("10.0 ms/100 sps",0);
ddlSr.addItem("4.0 ms/250 sps", 1);
ddlSr.addItem("2.0 ms/500 sps", 2);
ddlSr.addItem("1.0 ms/1000 sps", 3);
customizeDl(ddlSr);
cp5.addTextlabel("AcquireData").setText("3º Data Acquisition")
.setPosition(50,310).setColorValue(0).setFont(fontTit) ;
cp5.addButton(" Acquire data")
.setValue(0)
.setPosition(50,360)
.setSize(80,14)
.setId(5);
cp5.addButton(" Get Data File")
.setValue(0)
.setPosition(50,390)
.setSize(80,14)
.setId(6);
cp5.addButton("New Data Acquisition")
.setValue(0)
.setPosition(50,425)
.setSize(100,14)
.setId(7);
textFont(fontTex); //It select font type for every field that don't define font type
void customizeDl(DropdownList ddl) {
// Format DropDownList
ddl.enableCollapse();
ddl.setBackgroundColor(color(190));
ddl.actAsPulldownMenu(true);
ddl.setItemHeight(20);
ddl.setBarHeight(15);
ddl.captionLabel().style().marginTop = 3;
ddl.captionLabel().style().marginLeft = 3;
ddl.valueLabel().style().marginTop = 10;
ddl.setColorBackground(color(200, 200, 200));
ddl.setColorActive(color(0, 128));
ddl.setColorLabel(color(0,0,0));
void draw() {
background(myColorBackground);
switch(state)
case(1)://1º Configure Connection
rect(0,90,width,height-135);
fill(150);
cp5.controller("New Data Acquisition").setVisible(false);
break;
case(2)://2º Configure Data acquisition
rect(0,0,width,90);
fill(150);
rect(0,290,width,150);
fill(150);
break;
case(3): //3º Waiting for acquire data
rect(0,0,width,300);
fill(150);
cp5.controller("New Data Acquisition").setVisible(true);
break;
case(4)://4º Acquiring data from sensor
fill(150);
rect(0,0,width,350);
fill(244,3,3);
noStroke();
rect(160,355,map(count-ini,0,duration,0,200),19);
fill(0,0,0);
text(count-ini+"/"+duration+"s",240,370);
text("<-Data acquisition progress",370,370);
noFill();
stroke(0);
rect(160,355,200,19);
break;
case(5)://5º Downloading File
fill(150);
rect(0,0,width,380);
fill(244,3,3);
noStroke();
rect(160,385,map(count-ini,0,tamFile,0,200),19);
fill(0,0,0);
text((count*100)/tamFile +" %",250,400);
//text(count-ini+"/"+tamFile+" bytes",200,470);
text("<-Download file progress",370,480);
noFill();
stroke(0);
rect(160,385,200,19);
break;
case(6): //not used
break;
case(7): //7º File Downloaded
fill(150);
fill(244,3,3);
noStroke();
rect(160,385,map(250,0,250,0,200),19);
fill(0,0,0);
text("100 %",250,400); //200,420
text("<-Download file progress",370,400);
noFill();
stroke(0);
break;
void controlEvent(ControlEvent theEvent) {
// DropdownList is of type ControlGroup.
// A controlEvent will be triggered from inside the ControlGroup class.
// therefore you need to check the originator of the Event with
// if (theEvent.isGroup())
// to avoid an error message thrown by controlP5.
if (theEvent.isGroup()) {
// check if the Event was triggered from a ControlGroup
println("event from group : "+theEvent.getGroup().getValue()+" from "+theEvent.getGroup());
else if (theEvent.isController()) {
switch(theEvent.getController().getId()) {
case(1): //Connect with Geophonino in the seleccted port
int portSel=int(ddlCom.getValue());//Get selected port
println(portSel);
if (portSel==0)
status.setValue("Error, COM Port not selected.");
else
myPort = new Serial(this, Serial.list()[portSel-1], 115200);
myPort.bufferUntil('\n');
state=2; //When the connection is configured the state is changed
break; //END Connect with Geophonino in the seleccted port
case(2)://Refresh port list
println("Refresh port list");
String[][]itemsddlCom= ddlCom.getListBoxItems();
println(itemsddlCom.length);
if(Serial.list().length>itemsddlCom.length)
status.setValue("Error, COM Port not tetected, connect Geophonino and press Refresh... button.");
break;//END Refresh port list
case(3): //Send data acquisition configuration to Geophonino
println("Send Configuration");
String fileName= cp5.get(Textfield.class,"fileName").getText();
String dura=cp5.get(Textfield.class,"dura").getText();
duration= int(cp5.get(Textfield.class,"dura").getText());
int srSel=int(ddlSr.getValue());
int gainSel=int(ddlGain.getValue());
if (fileName.equals(""))
status.setValue("You must enter a file name");
else
if(fileName.length()>8)
Textfield fileNameField = ((Textfield)cp5.getController("fileName"));
fileName=fileName.substring(0,8);
fileNameField.setValue(fileName);
status.setValue("File name have been shorted to 8 characters, press SendConfiguration again");
else
if(duration<=0)
status.setValue("You must enter a numeric value in duration");
else
if(gainSel<1)
status.setValue("You must select amplification value");
else
if(srSel<0)
status.setValue("You must select sample rate");
else //All parrameters are OK, send configuration to Geophonino already
String configComand="conf_adq" + "&nomF="+fileName+"&overW="+overwriteFile+"&Gain="+gainSel+"&tR="+duration+"&sR="+srSel+"\n";
print(configComand);
myPort.write(configComand);
state=3; //When data acquisition is configured the state is changed
if (overwriteFile=="Y")
status.setValue("Configuration sent successfully, file will be overwrited");
overwriteFile="N";
else
status.setValue("Configuration sent successfully");
break; //END Send data acquisition configuration to Geophonino
case(5): //Acquire data
println("Acquire data");
String command="adq_now\n";
println(command);
myPort.write(command);
status.setValue("Initializing data acquisition...");
state=4; //When acquisition starts the state is changed
count=0;
break;//END Acquire data Now
case(6): //Get File
getLastFileNow();
break;
case(7):
println("7");
state=2;
break;
/*It's called when user select a folder to store datafile or close nagitation folder window*/
void folderSelected(File selection)
if (selection == null)
println("Window was closed or the user press cancel.");
folder="";
else
println("User selected " + selection.getAbsolutePath());
folder=selection.getAbsolutePath();
String rutaFile= selection.getAbsolutePath() + "\\" + cp5.get(Textfield.class,"fileName").getText();
println(rutaFile);
OutputFileRecived = createOutput(rutaFile);
/*Request last file recorded to Geophonino*/
void getLastFileNow()
String command="";
waitForFolder();
println("waiting");
if (folder==null | folder=="")
command="getF_ko\n";
println(command);
else
command="getF_now\n";
println(command);
/*Program still waiting while user select a folder to store data file*/
void waitForFolder() {
folder = null;
selectFolder("Select a folder to store data file:", "folderSelected");
while (folder == null) delay(200);
/*It's called when Geophonino is sending a data file*/
void getFile()
byte[] buffer = new byte[64];
int readBytes = myPort.readBytes(buffer);
for(int i = 0; i < readBytes; i++)
FileBuffer = append(FileBuffer, buffer[i]);
if (FileBuffer.length>=50000)
try
OutputFileRecived.write(FileBuffer);
OutputFileRecived.flush();
FileBuffer=null;
catch (IOException e)
println("Bytes received: " + FileBuffer.length);
count=count+readBytes;
if(tamFile != 0 && count >= tamFile)
myPort.clear();
println("Received");
saveFile();
/*It's called when data file have been received*/
void saveFile()
print( "Writing ");
print(FileBuffer.length);
println( " bytes to disk...");
try
OutputFileRecived.close();
count=tamFile;
status.setValue("File received succesfully");
state=7;
tamFile=0;
println( "DONE!");
void delay(int ms)
int time = millis();
while (millis () - time < ms);
/*It's called when data is available in the serial port*/
void serialEvent(Serial myPort)
if (state==5) //getting file
getFile();
else
//Write the incoming data into a String. '\n' is the end delimiter indicating the end of a complete packet
val = myPort.readStringUntil('\n');
if (val != null)
//Trim whitespace and formatting characters (like carriage return)
val = trim(val);
println(val);
if (firstContact == false) //no connection yet
if (val.equals("A")) {
myPort.clear();
firstContact = true;
myPort.write("Contacted\n");
println("Contact");
status.setValue("Connection established succesfully");
else //If we've already established contact, it keeps getting and parsing data
if(val.equals("conf_adq_filexist"))
status.setValue("Filename already exists, select other filename or press send configuration again for overwrite it");
overwriteFile="Y";
state=2;
if(val.equals("conf_adq_ok"))
status.setValue("Configuration was received succesfully by Geophonino");
if(val.equals("adq_now_ok"))
status.setValue("Data acquisition inicialized by Geophonino");
else
if(val.indexOf("adq_now_ok")>-1)
status.setValue("Acquiring samples for second: " + val.substring(10,val.length()));
count=int(val.substring(10,val.length())); //Update counter for progress bar
if (count==duration)
status.setValue("Data file " + cp5.get(Textfield.class,"fileName").getText() + " generated suscesfully." );
if(val.indexOf("sendF_size")>-1)
println("sendF_size");
tamFile=int(val.substring(10,val.length()));
println(tamFile);
if(val.equals("sendF_now"))
println("sendF_nowRecibido");
state=5;
status.setValue("File " + cp5.get(Textfield.class,"fileName").getText() + " open succesfully");
} //if we've already established contact, keep getting and parsing data
