I did not say that. I said it needs close to 10V to be FULLY ON. That device says the threshold voltage (when it STARTS to switch) could be up to 4V and the graph says at 5V it is only partially on. Too marginal for my liking but if you continue to use it be my guest. It is so close that anything could upset it.
Where is that coming from. It is during the prototyping phase that you want everything to be spot on. The last thing you want is potential built in problems while still experimenting. That is why you are at the position you find yourself in now.
If this is your thinking I don’t think much of it. You would be better if you could guarantee everything to be spot on before you went much further.
Thanks. Looking at the datasheets the inputs for VIN for Uno and Nano are 7-12. The load I am looking to power is specified as 5V, so if I use anything higher than that to power the microcontroller I would then need a voltage divider to get the voltage down to where I need it for the load if I am powering both with a single power source. Perhaps going into the microcontroller via the 5V output pin is the way to go?
I am assuming if I only have 5V going to the 5V output pin and nothing going to barrel jack or VIN it should be ok?
3V3/5V Pin
Avoid this option since the risk of damaging the onboard voltage regulator is high. It can be done safely if the applied voltage to the 3V3 or 5V pins is not higher than the input voltage of the voltage regulators.
What I mean is that although the orange terminal is designed for a PCB, it also works on a breadboard well enough to ascertain whether a circuit is working or not. The short pins does however make it unsuitable as a longer term solution as it can easily be knocked loose. For that I would transition to a soldered PCB.
You can power the UNO this way, but it is not recommended and there is a risk of damaging it. The best solution is to use a 9V or 12V power supply, use the barrel jack on the UNO, and a regulator (not a voltage divider) for the device that needs 5V. That also provides good isolation for the power to the two components, which is a problem you have already run into.
Thanks. I can picture the power source going from the mains to the barrel jack into the UNO, but how do I splice it off to the voltage regulator for the 5V device?
If you are using a DC power supply you could use an end like this to get 9-12V and power the Arduino through it’s Vin. You can then use the 9-12 with a voltage regulator.
I am assuming this was where these came in.
The Arduino has an on-board regulator you can use for 5V but you may want to opt for another 5V regulator such as this one to ensure your heating pad can draw enough current.
Yes, that sounds good. I would still need to get a 9VDC mains adaptor with active and neutral wires free to plug into the 2-6 adaptor. I guess I could plug the power supply into a barrel jack mounted on the PCB and then split off into the 2-6 from there? Perhaps that is what @Jack was referring to here? I am assuming he may have meant to post a picture or a link?
Just cut the barrel jack off the adapter and wire it straight into the 2 side of the 2-6 adapter. Wiring power through the breadboard is not going to work well. Give yourself at least 10cm length back from the barrel plug in case you want to use the plug with some other device in the future.
That what I was thinking! Just wondering if there was a non-destructive way around it but I’m ok with that approach. That is how my 5V USB power supply into orange terminal was set up.
It is OK to input 5V to the “5V” pin. this can be an input OR output.
The 3.3V pin is output only. You CANNOT input 3.3V to this pin.
What do you mean by "5V USB power supply. It is not shown in your pics. Is it 5V derived from a computer port or a 5V charging supply with USB outputs. I have been going along the assumption that it is a POWER SUPPLY. If it is a charging sort of thing it could be anything.
It’s a micro USB cable whereby I lopped off the plug and connected to the orange terminal so I can connect to breadboard and PCB. It is a 5V 1A Apple voltage regulator.
Hi Dion
As long as it is a SUPPLY as against a CHARGER (phone etc) it should be OK although at only 1A it could struggle running everything given tat the inrush current (published cold resistance of heater 8.3Ω) of the heater is 0.6A if near the limit you could get a voltage sag at switch on with everything connected. This could create a situation where the Mosfet never gets to switch on. Might explain why the heater seems to be OK when connected directly. This would not be helped by using that Mosfet which I think is pretty marginal at best. I still think you would be better using the Mosfet I suggested earlier which should be fully ON at 5V
Can you try a power supply with more current capability like 2A plus. Doesn’t matter how big you go.
Add on:
If you are interested this is how I power a breadboard
This is a piece of 22AWG tinned copper crimped with the stranded wire into a bootlace ferrule then inserted into the breadboard holes. Incedently 22AWG (0.71mm) is the maximum recommended diameter for these contacts.
Hmmm, actually it is a charger we used for iPhones. This could be why I struggle to achieve 450mA . I also tried with 2.4A charger this morning and was able to get to 470mA, which is still short of the ~600mA I should be drawing.
Getting a decent power supply and the mosfet you have recommended should go a long way to resolve some of my problems.
Hi Dion
Although they MIGHT be OK chargers may not be particularly “clean” as there is no real reason they should be. Power SUPPLIES on the other hand go to some lengths to make sure they ARE “clean”.
Regarding your orange terminal block. I have some of those so I just tried one. It would not go into my quality “Wish” board at all. I have another “quality” board and the terminal would not insert into this either. Measurement showed the pins to be 1.02 X 1.03mm and the contacts are quoted 0.7mm max. I did find however that I could force it into a “cheapo” breadboard but only about 1mm which is far from ideal. Even if I could force it in further (longer pins) it would probably destroy that contact.
My suggestion still stands. Modify your method of powering while using a breadboard and mark those contacts you have been using as suspect for future use.
I think you might get some results there. Don’t forget the series gate resistor (about ik should do to limit the inrush to 5mA) as to drive it from Arduino or similar it will be required.
Hi Dion
I know this is late and goes back to your original post but!!
I just had a look at that video. What a lot of absolute garbage. That would be the most unscientific scientific experiment I have ever seen.
Not too bad until the fool put his hand on the heater. What sort of an idiot would do that. If the heater had any real grunt he could have well done himself some damage.
His next statement was a classic. How by placing his hand on the heater he “INSULATED” it and lowered the temperature. The temperature lowered because the heater was trying to heat up his hand and did not have enough power to retain its heat. If you covered both sides of the heater with thermal insulating material the heater would get hotter as there would be no thermal path to dissipate heat. But in this situation the heater could not do any real work.
Disregarding that video and back to the heater. 5V @ 0.6A is only 3W. Not a lot of heating power. One suggested use would be as a hand warmer which could be about as far as you would get I am afraid. A Transistor or Mosfet dissipating 3 W would probably not even require a heat sink. If a resistor it would be warm to hot to the touch but would not do much damage.
Try it. Get a 10Ω 5W resistor and apply 5V. This will give you 2.5W. If you can increase the voltage to 5.5V this will produce about 3W. The 5W resistor will get fairly hot, a 10W one will be a bit cooler as it is bigger and able to dissipate more heat into the air but neither one will be really hot.
What I am getting at is that this heater (only being 3W) will not have a great deal of heating power if your area or subject has any volume to speak of. I don’t know what the requirements of a dough proofing box is but I would be surprised if this little heater could cope.
Thanks Bob, that is the exact thing I experienced even when I did get it to work. It took an hour to heat an empty plastic tub from 16C to 17C! Not much use when I want it to warm a 1.5kg mass to 24-25C! The tub isn’t very big, perhaps 30x40x10cm. It’s plastic so a reasonable insulator but even so the thermal losses were eroding most of the heat generated.
I have a 46.5ohm heating element I have removed from an old toaster oven i am considering connecting to 12V just to see what will happen, but my basic understanding of ohms law tells me it will still be around 3W?
Hi DionI think to have any success with anything you are going to have to minimise thermal loss through the walls and use a thermally insulated container like a fridge or a wall oven.
Be a bit careful here. If you measured this as 46.5Ω with a DMM that will be the COLD resistance This will be greater or even considerably greater when the element heats up and won’t necessarily be the operating resistance. The only real way to measure this operating resistance is to measure the voltage and current then calculate it. The wattage is simply the voltage across the element multiplied by the current.
The measurement of current should be ideally non invasive like a clamp meter.
There is a quirk you might not know about with a clamp meter measuring DC. It is residual magnetism in the core laminations interfering with the hall device sensor. You have to continually (between measurements) zero the meter with no current through it or you can end up with a substantial error.
That is correct if that is the operating resistance so it is not going to get very hot.
240V at that resistance is about 1240W which is more like it for a toaster. As the element heated up it possibly could settle down to something near 1kW
