I need to help on finalising temp code, i used chat gpt to help me out until now.
Wondering if i get some help on the code.
Equipment used;
AIM:
- Using ESP32 to read temperature from a DS18B20 sensor and battery voltage via the UMS3 library
- Sending the readings to a influxd cloud server
- Send the readings when the usb power is on ( if usb_presence=1)
- Wanna have led module code to be function when the usb power is on (usb_presence=1)
- Store data on ESP32 until if there’s NO a WiFi connection
- Store data on ESP32 until if there’s NO a influxdb connection
- Disable WiFi when the ESP32 is running on battery mode when the usb presence is =0
- Shut down the ESP32 if the battery reaches 3.60V or after 4 hours (whichever is first) if the usb presence is =0
I already have the base code for reading & sending data to influxdb
Also have the led module code.
Code for the Data Logging to influxdb
#include <Arduino.h>
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <WiFiMulti.h>
#include <InfluxDbClient.h>
#include <InfluxDbCloud.h>
#include <UMS3.h>
#include <esp_bt.h>
UMS3 ums3;
WiFiMulti wifiMulti;
#define DEVICE "eps32-s3"
#define WIFI_SSID "SSID_OF_NETWORK"
#define WIFI_PASSWORD "PASSWORD_OF_NETWORK"
#define WIFI_SSID1 "SSID_OF_NETWORK1"
#define WIFI_PASSWORD1 "PASSWORD_OF_NETWORK1"
#define WIFI_SSID2 "SSID_OF_NETWORK2"
#define WIFI_PASSWORD2 "PASSWORD_OF_NETWORK2"
#define WIFI_SSID3 "SSID_OF_NETWORK3"
#define WIFI_PASSWORD3 "PASSWORD_OF_NETWORK3"
#define INFLUXDB_URL "http://10.20.2.50:5006"
#define INFLUXDB_TOKEN "3n56566UfmFARbfTey0xLliyjQaNmFNIe0gv0qX6Ls7U7EqVocMEWTbihsA=="
#define INFLUXDB_ORG "928c8dd365c43aa5"
#define INFLUXDB_BUCKET "farm"
#define TZ_INFO "AEST-10AEDT,M10.1.0,M4.1.0/3"
InfluxDBClient client(INFLUXDB_URL, INFLUXDB_ORG, INFLUXDB_BUCKET, INFLUXDB_TOKEN, InfluxDbCloud2CACert);
Point sensorReadings("measurements");
#define ONE_WIRE_BUS 1
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
void initDS18B20() {
sensors.begin();
void setup() {
Serial.begin(115200);
ums3.begin();
sensors.begin();
WiFi.mode(WIFI_STA);
wifiMulti.addAP(WIFI_SSID, WIFI_PASSWORD);
wifiMulti.addAP(WIFI_SSID1, WIFI_PASSWORD1);
wifiMulti.addAP(WIFI_SSID2, WIFI_PASSWORD2);
wifiMulti.addAP(WIFI_SSID3, WIFI_PASSWORD3);
btStop();
while (wifiMulti.run() != WL_CONNECTED) {
Serial.print(".");
delay(500);
Serial.println();
initDS18B20();
sensorReadings.addTag("device", DEVICE);
sensorReadings.addTag("location", "farm");
timeSync(TZ_INFO, "pool.ntp.org", "time.nis.gov");
if (client.validateConnection()) {
Serial.print("Connected to InfluxDB: ");
Serial.println(client.getServerUrl());
} else {
Serial.print("InfluxDB connection failed: ");
Serial.println(client.getLastErrorMessage());
void loop() {
sensors.requestTemperatures();
float temperature = sensors.getTempCByIndex(0);
float batteryVoltage = ums3.getBatteryVoltage();
delay(1000);
int usbpresence = ums3.getVbusPresent();
sensorReadings.addField("temperature", temperature);
sensorReadings.addField("battery_voltage", batteryVoltage);
sensorReadings.addField("usb_presence", usbpresence);
Serial.print("Writing: ");
Serial.println(client.pointToLineProtocol(sensorReadings));
client.writePoint(sensorReadings);
sensorReadings.clearFields();
if (wifiMulti.run() != WL_CONNECTED) {
Serial.println("Wifi connection lost");
Serial.println("Wait 30s");
delay(30000);
Code for the LED MODULE
#include <Adafruit_NeoPixel.h>
#define PIN 2 // Input your RGB LED module GPIO pin
#define NUM_LEDS 1 // Number of LEDs in your module
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
int DELAYVAL = 500; // Time (in milliseconds) to pause between pixels
void setup() {
strip.begin(); // Initialize the NeoPixel library
strip.show(); // Initialize all pixels to 'off'
void loop() {
rainbow(60*1000/256); // 60 seconds divided by 256-color spectrum
strip.clear();
strip.show();
delay(60 * 60 * 1000); // Wait for 60 minutes
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*2; j++) { // repeat twice for a smoother transition
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
