This is a placeholder topic for “HiFiBerry Steel case for DAC2 and Pi 4” comments.
This is our most robust case, made completely from steel. It is ideal for environments that need something rugged.
Read moreThis is a placeholder topic for “HiFiBerry Steel case for DAC2 and Pi 4” comments.
Read moreI want to use this witha Pi 4 and the HiFiBerry DAC2 ADC Pro - that will fit fine as well no?
Hey there, @Harry319626, and welcome to the forum. Glad to have you here.
As long as you’re using the standard board stack-up for the Pi 4 and DAC2 Pro, the cut-outs and internal clearance should suit it. If you’ve got an unusual header, extra wiring, or a non-standard HAT spacer arrangement, that’s the main thing I’d double-check. Otherwise you should be right.
