I think that you’ve missed a few points, and there’s a couple of things that I will agree on.
I didnt explicity say it, and I rounded the input voltage in what I said to be brief, however I AM supplying the BMS with 12.6v (I did say 12v)
Secondly, the BMS will not over volt the cells, that is litterally it’s job.
Yep, totally understand that, no question.
Not sure what you mean by this.
If you mean only the Pi, not the screen or other things, then that is absolutely incorrect.
It is sitting on my bench now, happily running the Pi 4, HDMI screen, 3 x DC encoder motors and DSLR camera, only from the 3 x 18650s connected to the BMS, then the 12v output converted down to the 5v for the Pi, 6v for the motors and 9v for the camera.
You are totally correct on this front and I missed that, easy to fix though by putting diodes on the supply line.
I get it, you dont understand what I am trying to do.
Your solution doesnt meet my requirements, no matter how many times it is raised.
I am not saying that it wont work, it will, but I need to solve all my requirements, not just one.
Yes it totally does.
I’ll go back, again, to my requirement list.
The Pi rebooting in ‘normal’ circumstances is not the end of the world, however it is absolutely not an ideal situation for a couple of reasons.
- hard rebooting a Pi will eventually corrupt the SD card, just a fact of life. Avoiding that is obviously ideal.
- For the short term application of my hardware I have a hard requirement that the Pi isnt rebooted, it needs to stay connected and do so for config, transport, moving to specific location and then final setup before it can be repowered by the much more permanent power supply.
It is specifically not ideal to do this with batteries that are external to my setup as multiple boxes joined by a wire tend to get knocked, bumped and eventually disconnected.
This is why I require the backup power to be internal to my device.
It’s not ideal for that supply to have to be cabled externally to my device to be plugged and unplugged with the external battery.
This is due to the fact that all of this is for a camera slider dolly.
It ALL moves and anything that poses a snag risk is not acceptable.
Yes, I could mount all that internally to the device and have a switch, but past experience tells me that switches get knocked and in the dark (which is where this all works) it’s really easy to switch the wrong switch or understand what position the switch needs to be in for what mode.
This is entirely the reason why I need the solution to be capable of running by itself or when powered from a single external cable.
As I said, i do appreciate the help Bob.
