In regards to the adafruit product you stock Powerboost 1000c it says that it provides an output of 1A, so as a Raspberry Pi requires 2.5A, this wouldn’t be sufficient? Or is it saying the charging current is 1A, but the output current can reach 2.5A?
If the latter can anyone recommend a suitable LiPo that can be used in conjuction with this PowerBoost 1000c for my raspberry pi?
I have seen a Raspberry Pi 3 running on one of these but you can’t pug in any USB devices that take much power or do anything that pushes the Pi hard. So technically there are some tasks you can use it to power a Pi with but not all.
I’ve been using the PowerBoost 1000C with an RPi 3B+ and a device drawing some power from the USB; it works fine for me, but the power draw is less than the 2.5A ceiling. More like 1.2A peak, less than 1A typical. Note that for my application the Pi is not being pushed hard.
I did find that sub-standard cabling caused massive issues early on, so if you do use this solution make sure you have good cabling and connections; a 0.5 ohm (dodgy) cable caused a voltage drop that was a real headache!
If you’re going to be pushing the Pi hard or using a bit of power via USB, you probably need a different power solution.
