How can I use an AS5600 sensor on a rotating platform while keeping the Arduino stationary?
I’m designing a wind vane system where a wind vane rotates freely with the wind, and a motor rotates a separate platform to align with the wind direction.
I’m using an AS5600 magnetic encoder with a magnet attached to the wind vane to measure its angle.
The issue is that the AS5600 needs to rotate with the platform to measure the wind vane’s angle relative to it. However, my Arduino Nano must remain stationary, meaning the wires connecting the AS5600 to the Arduino would twist as the platform rotates.
I’m trying to keep the design simple and avoid using additional sensors if possible.
from a quick read and google, Im assuming the AS5600 encoder is from a magnet that is near the “sensor” chip. and is measuring the rotation based on the poles of that magnet.
If that is the case, put the magnet on the moving part and leave the sensor fixed, thus no cable issues.
e.g. : the wind direction sensor | Details | Hackaday.io
Hi Nemanja335463
I am assuming here that this platform rotates with the wind direction NOT the speed. In this case this would be fairly slow moving. Is this correct and you want to measure the angle WRT what. If establishing wind direction I would think the reference would be the earth magnetic field.
Being slow moving, SLIP RINGS would be the simplest if they can do the job. Core have a selection of 7 types. Search “slip rings” in the search box.
Cheers Bob.
This will measure the magnetic direction but if you want TRUE North you have to apply the correction which depends on where you live. Where I live that is 12.8º
Yeah, I think slip rings might be the way to go, thanks for the suggestion
