I am in the process of researching for a power / current measuring data logger.
I will be using Arduino MKR Zero because of its onboard microSD card slot.
My design looks like this.
In order for the INA219 to function properly, the power source being measured must share a common ground with the MCU. I assume this is correct, please correct me if I am wrong. I hope bringing the negative 24VDC to the MCU’s ground won’t cause issues to the board.
After reading someone else’s project who developed a module that has an isolated measured voltage so the INA219 and the MCU won’t share a common ground, I am confused whether or not I am on the right track. Thank you so much for any feedback!
Just want to clarify that the 24VDC power is supplied by a power supply that is plugged into the main 240VAC and it outputs 24VDC 20A. The common gnd therefore will be the negative wire of the power supply. The power supply of course earthed at the wall outlet.
