Hi Folks.
I’m trying to install Adafruit Blinka on my Pico WH so I can use the Adafruit LC709203F LiPoly / LiIon Fuel Gauge and Battery Monitor.
Using Thonny, when I upload the Blinka/src folder I get a ton of errors like…
Could not write next block after having written 0 bytes to /src/adafruit_blinka/board/orangepi/orangepi3b.py
…and eventually…
PROBLEM IN THONNY’S BACK-END: Exception while handling ‘upload’ (thonny.plugins.micropython.mp_back.ManagementError: Command output was not empty).
See Thonny’s backend.log for more info.
You may need to press “Stop/Restart” or hard-reset your MicroPython device and try again.
Process ended with exit code 1.
Enlightenment would be appreciated!
Cheers.
