This is a placeholder topic for “Interface Cable - SMA Male to SMA Female (25cm, RG174)” comments.
This is a basic SMA male to female connector cable at 25cm in length and RG174 housing…
Read moreThis is a placeholder topic for “Interface Cable - SMA Male to SMA Female (25cm, RG174)” comments.
Read moreThe linked drawing on the product description bears little resemblance to the product pics. This product is depicted as having a panel mount SMA connector on one end. The drawing shows a cable mount connector on both ends.
Thanks for the catch, @Robert93820,
I will go ahead and update the page to remove the incorrect datasheet.
Hi Jane
It would be useful if you are able to replace it with the correct one.
Would answer Luke’s question (and probably others) in another post.
Agreed.
I will reach out to the supplier for a correct mechanical drawing that I can add to the page.
It’ll be a lot better than anything I would scribble down.
Hi Jane
I just noticed that the product page for the reverse polarity version of this cable (SKU CAB-22037) has exactly the same drawing linked. Even the same drawing number. I suppose that 640.1662 is the drawing number. Appears on both cable descriptions anyway.
