can you use DFR0229 with an Adafruit ItsyBitsy M4 Express. Have 5V available to power the SD module. the question is can the ItsyBitsy handle the SPI signal from the module. Can’t find anything on the internet specifying logic levels for either component.
The SD breakout is 5V. The Itsy bitsy is 3.3V.
Use logic level converters to connect the pins between the boards. When you know how many pins need to be connected, you can select something from this link.
