sudo sh -c ‘echo 0 > /sys/devices/pwm-fan/target_pwm’
but neither of which are able to stop the fan. The fan just keeps running at maximum speed until I remove power. Does anyone know what the problem might be, or how to troubleshoot the problem.
The follwowing is a status response for: sudo service automagic-fan status
● automagic-fan.service - Automagic fan control
Loaded: loaded (/lib/systemd/system/automagic-fan.service; enabled; vendor pr
Active: active (running) since Wed 2021-08-11 15:29:22 AEST; 24s ago
Process: 8313 ExecStopPost=/bin/sh -c /bin/echo 0 > /sys/devices/pwm-fan/targe
Process: 8315 ExecStartPre=/bin/sleep 5 (code=exited, status=0/SUCCESS)
Main PID: 8330 (python3)
Tasks: 1 (limit: 4172)
CGroup: /system.slice/automagic-fan.service
└─8330 /usr/bin/python3 -u /usr/local/bin/automagic-fan/fanctl.py
Aug 11 15:29:17 carl-desktop systemd[1]: Starting Automagic fan control…
Aug 11 15:29:22 carl-desktop systemd[1]: Started Automagic fan control.
Aug 11 15:29:22 carl-desktop python3[8330]: Maximizing clock speeds with jetson_
Aug 11 15:29:22 carl-desktop python3[8330]: Setup complete.
Aug 11 15:29:22 carl-desktop python3[8330]: Running normally.
lines 1-15/15 (END)
So for some context, I have three Jetson Nanos, each driving their own camera, for a film I’ll be making over the next month. I have three of them running simultaneously, but the fans are way too loud during a take, so I want to turn the fans off during a take, and then resume the fans in between the takes. Just on/off.
I eventually want to do this from software I’ve written for the cameras (in C++), but that’s not going to happen if I can’t first get it to happen with a terminal command or script.
Seems like this thread got left behind a bit! (not like us at all!) I came across it while fixing up our product pages, and I’d like to get to the bottom of this for you (and others), but I get that you’ve probably moved on from this problem quite a bit, so if you don’t reply, I’m sure we’ll get it.
Does ls /sys/devices/pwm-fan come up with anything?
This isn’t a part of the automagic file control install script, so if that fails, it may point to a deeper issue like hardware
