Does anyone know if the Waveshare LCD1602 RGB is compatible with the HD44780 instruction set? Including display on initialisation?
I have it working on my raspberry pi 4b using the demo python code, however when I try using it with a project that assumes a HD44780 display, it doesn’t turn on.
Pretty confident that I have set the address correctly, as using i2cdetect, I can see the I2C address is 0x3e, which aligns with the python code 0x7c>>1.
Hi Daniel
A couple of years ago I purchased a Waveshare 1602 display (Waveshare number appears to be 19537) which is I think the RGB backlight version of this one in question. I was attempting to use the supposed Waveshare library as on their web site.
I played with this using an Arduino R3 for some days and could get nothing to display properly. Just a load of rubbish with a included just the character blocks described above. I tried printing using a couple of different ASCI codes but to no avail It did come up with some strange characters which I could not identify or correlate with the ASCI codes I knew about.
It went back into its box and has been there ever since. One contributor suggested I try the DfRobot library but I did not get around to it. I opted for a 1602 display with the little I2C adaptor board mounted on the back. Works fine.
