LifePo4 LED Meter - LM3914 4S DOT 5 x LED Meter
Hi All,
I would like run 5 led’s to gauge approx status derived from voltage from a scale of high 13.5v to low 12.8v. I would much appreciate a diagram that utilises an LM3914 and high and low 10k trimmers.
ie:
Full max 13.5
Full min 13.47
High 13.4
Mid 13.25
Low 13.1
Empty 12.8
Would this work and how would I go about it? Thanks in advance
Hi Tria
At 3.2V per cell the nominal voltage for a 4S battery would be 12.8V. This is NOT the empty voltage which is 2.8V / cell or 11.2 for 4S so I would think the low level could safely be 12V
Max charging voltage would be 3.6V /cell or 14.4V for 4S.
Above from Wikipedia.
Thanks Bob,
Do you know how to wire up an LM3914 chip to achieve this?
Hi Tris
I think the LM3914 is designed to drive 10 LEDs. So I don’t know about 5. Maybe you can use every 2nd driver. I think the chip has its own divider and maybe you just set the end points and it becomes a linear scale.
I do note there is quite a bit of application notes in the TI (Texas Instruments) Date sheet. I have not time to study it in depth so perhaps you might get enough information yourself or just google LM3914 and see if anything comes up.
Thanks Bob, i got close but intermittent led behaviour. I thought some one on this forum would be able to sketch a diagram quite quickly. Let’s see. much appreciated
Hi Tris
Sorry about that. I have a couple of car issues and a TV reception problem I am trying to sort at the moment. If you don’t have any joy I will have a look for you when I get a chance
