Linear Actuator
I am looking for a linear actuator that has adjustable stroke between 30 and 60mm. Force required is minimum of 100kgs and has IP66 rating. I also require a controller.
My PH sensor will send a signal to your controller which will pull (retract) by the preset stroke (approx. 40mm) and then immediately return to the start position. The stroke can be larger but I will only be using 0-60mm maximum.
Do you have a system to suit my application ?
Regards,
Steve
Hi Steve,
This should work:
Pair with this to drive it:
and then control that with any micro-controller!
