Lora RFM95w with Arduino, node to node, I need to send multiple variable values from one node to another, I can send a string containing ALL the values but they cannot be used at the receiver, they need to be separate values. Is there a special format that I need to use or is this just not possible as i have not found any but the most simple examples with only one variable being sent.
thanks in advance.
Heya Doug,
You may find some nuggets in this tutorial:
Of note, how we use ustruct.pack and ustruct.unpack to create packets/payloads which contain various object types
I have devised a way to do this, but there must be a better answer.
I have applied the values to an array, then one by one send the value as a String, at the receiver i take each value as it arrives and convert it to an Int this can then be stored in an array and used to populate an Int variable. Here I have just used it as it arrived.
//Sender
#include <SPI.h>
#include <LoRa.h>
int myVals[] = {50, 100, 150, 200, 254};
int counter = 0;
int i = 0;
void setup() {
Serial.begin(9600);
while (!Serial);
Serial.println("LoRa Sender");
if (!LoRa.begin(915E6)) {
Serial.println("Starting LoRa failed!");
while (1);
void loop() {
Serial.print("Sending packet: ");
Serial.println(counter);
// send packet
for (i = 0; i <= 4; i++) {
LoRa.beginPacket();
LoRa.print(myVals[i]);
LoRa.endPacket();
counter++;
Serial.print(i);
delay(100);
delay(500);
//Receiver
#include <LoRa.h>
String LoRaData;
void setup() {
pinMode(5,OUTPUT);
Serial.begin(9600);
while (!Serial);
Serial.println("LoRa Receiver");
while (1);
Serial.println("LoRa Initializing OK!");
void loop() {
// try to parse packet
int packetSize = LoRa.parsePacket();
if (packetSize) {
// received a packet
Serial.print("Received packet '");
// read packet
while (LoRa.available()) {
//Serial.println((char)LoRa.read());
LoRaData = LoRa.readString();
Serial.print(LoRaData);
// print RSSI of packet
Serial.print("' with RSSI ");
Serial.println(LoRa.packetRssi());
int d = LoRaData.toInt(); //convert String to Int
Serial.print("Int Value = ");
Serial.println(d);
Serial.println("");
analogWrite(5,d);
Running on an Arduino Nano and Pro Mini Clone. If anyone knows how to convert a String to a Float Variable please post here.
Here are the mods for an Array…(EDITED…this version uses array value 0 as a flag to reset the count seems to be stable.)
//Sender
#include <SPI.h>
#include <LoRa.h>
int myVals[] = {0, 50, 100, 150, 200, 254};
int counter = 0;
int i = 0;
void setup() {
Serial.begin(9600);
while (!Serial);
while (1);
void loop() {
// send packet
for (i = 0; i <= 5; i++) {
LoRa.beginPacket();
LoRa.endPacket();
counter++;
Serial.print(i);
delay(100);
delay(5000);
//Receiver
#include <LoRa.h>
String LoRaData;
int i = 0;
int value1=0;
int value3=0;
int value5=0;
int myVals[] = {0, 0, 0, 0, 0, 0};
void setup() {
pinMode(5,OUTPUT);
Serial.begin(9600);
while (!Serial);
while (1);
void loop() {
if (packetSize) {
// read packet
//if (i >= 4) {i = 0;}
if(d == 0) {i = 0;}
myVals[i] = d;
Serial.println(d);
Serial.print("Array Int = ");
Serial.println(myVals[i]);
Serial.println("");
i = (i+1);
analogWrite(5,d);
value1 = myVals[1];
value3 = myVals[3];
value5 = myVals[5];
//just to prove values of variables
Serial.println (value1);Serial.println (value3);Serial.println (value5);
